Thread: rear window
Results 1 to 4 of 4
  1. #1 rear window
    canada
    hey guys my rear window in my 07 get moisture inside at the bottom fairly easy. I have look and look and I cannot find a leek anywhere, there are no puddles anywhere inside the trunk or car. is this normal or is there somewhere I can check the window seal that I'm missing?
  2. #2 Re: rear window
    GT Level Member GMCustomerService's Avatar
    Michigan
    echarleswhyte,
    Would you please PM me the last 8-digits of your VIN, so I may look into this further for you?
    I look forward to your reply.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  3. #3 Re: rear window
    Oct 2011
    Canada
    Was this ever solved??? Mines pretty bad on the bottom, and on certain nights it will creep up the whole rear window.
  4. #4 Re: rear window
    check your trunk for moisture, down where the spare tire is. check the weather stripping as well for damage. and also the strut towers, if rusted or splitting water can get inside the trunk.
  1. graphics on rear window
    By Sudden in forum Visual/Body Modifications
    Last Post: 10-17-2012, 12:31 AM
  2. Just the rear window
    By FriboRage in forum Visual/Body Modifications
    Last Post: 04-26-2012, 08:49 AM
  3. Rear Window Just Dropped
    By Burgundyman in forum General Tech Discussion
    Last Post: 09-27-2011, 07:14 PM
  4. 1965 Rear Window
    By buckkunz in forum Shops and Community Heroes
    Last Post: 05-11-2010, 05:22 AM
