Thread: vibration after lowering car
Results 1 to 12 of 12
  1. #1 vibration after lowering car
    crossville,tn
    hey guys just installed a set of b&g lowering springs using stock struts im having a wooble at lower speeds ..i have researched and havent found much on the 5.3s any help would be much appriecated....my car is a 2006 pontiac gxp grand prix 5.3
  2. #2 Re: vibration after lowering car
    Florida
    Is it mostly during acceleration??
    By lowering the car, you threw off the axle geometry and the car is going to shake some. Get a set of engine/trans spacers to help correct the geometry.
    Also be a solid idea to go get the car's tires balanced, and the car aligned. Should help some too.
    And lastly, did you make sure you tightened everything up really well? didn't leave anything loose?
  3. #3 Re: vibration after lowering car
    crossville,tn
    i just put new wheels and tires on and i bought springs and local gm dealership installed springs and did a four wheel alignment i also put a shorter dog bone on too and that didnt help wobble and also installed pogo washers too ...ihavent done the spacers yet ....
  4. #4 Re: vibration after lowering car
    crossville,tn
    who sells spacers for the 5.3 gxp
  5. #5 Re: vibration after lowering car
    Florida
    Not sure about the 5.3, but you can go buy some metal stock, and cut/drill your own. That's what I did.
  6. #6 Re: vibration after lowering car
    Arizona
    Toss the shorter dog bone our engine mounts are a a different ball game compared to the 3.8 guys by putting that shorter do gone means you had to severely compress the front lower mount and stretched the rear Mount...not good
  7. #7 Re: vibration after lowering car
    crossville,tn
    So the spacers should cure it?i got the short dog bone from zzp racing he lead me that way instead of spacers im new to the front wheel drive stuff...
  8. #8 Re: vibration after lowering car
    Jan 2009
    Tallahassee, FL
    Spacers will do it. I'm tucking tire now and don't get any vibration with spacers.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #9 Re: vibration after lowering car
    Arizona
    I'm telling you you won't even need spacers if anything just get those lower mounts replaced first OK m lowered on SSC with no vibration whatsoever. Oh and I have a Gxp too. Toss the short dog bone put the OEM one back.
  10. #10 Re: vibration after lowering car
    Jan 2009
    Tallahassee, FL
    B&G springs are much lower than SSC springs. I'm not surprised you're not feeling vibrations. He'll need spacers. I needed them with my Eibachs
    77 Morris Garage B
  11. #11 Re: vibration after lowering car
    Arizona
    Quote Originally Posted by Sandman View Post
    Were on bilsteins though spring perch sits higher. Than regular 97-03 with the same combo.
  12. #12 Re: vibration after lowering car
    Spacers would also help by putting the cv axles back in the correct pistons.
    As cheap as speakers are its worth the little effort.
    And of course check your mounts while you're at it.
    04 Comp G.
  1. vibration at high speeds after lowering
    By des19 in forum General Grand Prix Discussion
    Last Post: 05-13-2013, 04:04 PM
  2. Lowering Vibration.. I think
    By cmal37 in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2012, 10:31 PM
  3. vibration....Lowering springs?
    By BillGTX in forum Introductions/Noob Questions
    Last Post: 07-15-2011, 11:41 PM
  4. Terrible acceleration vibration with lowering springs
    By real diehl in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2010, 09:33 PM
