Thread: 04+ Roof rails
Results 1 to 11 of 11
  1. #1 04+ Roof rails
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Are there any roof rails for a 2004 gp?
  2. #2 Re: 04+ Roof rails
  3. #3 Re: 04+ Roof rails
    The 97-03 Rails are about an inch-two short as well...
  4. #4 Re: 04+ Roof rails
    Wichita
    ^^^Ive wondered about that for a long time.
  5. #5 Re: 04+ Roof rails
    GT Level Member Kendra's Avatar
    Feb 2008
    Fredericksburg, Virginia
    If you can find a good body shop to make up the difference or... you can dead center them and get away with it.
    1987 Fiero GT | Purchased from Original Owner | 5spd | Stock
    2009 G8 GT | Daily Driver | "Some Mods"
  6. #6 Re: 04+ Roof rails
    Wichita
    ^^^Anyone one here ever done that?
  7. #7 Re: 04+ Roof rails
    GTP Level Member
    Nov 2011
    Kansas
    Look for the ride thread: Rengenesis........ he has rough rails on his car.
    Edit: here is the link to it.
    http://www.grandprixforums.net/gpf-m...4-a-57872.html
  8. #8 Re: 04+ Roof rails
    I've got a pair I'm almost finished making FIT the car properly. I have one more epoxy layer to do and sand, then I should be ready for a matte black vinyl wrap and install. It's been a PITA to modify.
    To clarify, they are about 3/8" too short. They are also tapered at each end, which the 2004+ roof line does not do. I had to widen the rails for 2-3 inches on each end and also lengthen them.
    They look like poo right now with layers of epoxy, but they are smooth.
  9. #9 Re: 04+ Roof rails
    GT Level Member MRANGRYGTP's Avatar
    Niagara, Ontario, Canada
    I was going to say, they arent 2 inches short, but they arent perfect without some manipulation... Damnir has taken the meticulous approach...
    2009 Holden Commodore SSV Redline Replica - 2009 BMW 328I M Sport - 1992 GTA Trans Am - Traded: 2004 GTP COMP G "Regenesis"
  10. #10 Re: 04+ Roof rails
    I think you meant to say "the stupid" approach. This is such a PITA I can't even begin to elaborate. Now that I have them pretty much done (or so I thought), vinyl looks terrible since the ends are not completely uniform (flat). I've started blasting it with filler/primer and I'll start sanding them out to see if they can be saved (well, look better).
  11. #11 Re: 04+ Roof rails
    Jan 2012
    Philadelphia
    you can use finishing putty that might help a little bit to get in more flat and fill in any small imperfections
  1. roof rails
    By kjohnson in forum Visual/Body Modifications
    Last Post: 10-29-2013, 03:34 PM
  2. Roof Rails
    By GAFF in forum Visual/Body Modifications
    Last Post: 08-16-2010, 09:48 AM
  3. ? about roof rails
    By beast55 in forum Visual/Body Modifications
    Last Post: 05-26-2009, 12:47 PM
