Thread: Speaker questions
Results 1 to 4 of 4
  1. #1 Speaker questions
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Hi i have a 04 GP GTP Comp G...i had a Pioneer AVH-P3300BT head-unit installed and the loudness of all the speakers seemed to drop drastically. I was wondering if there is a way to fix that? and also the rear speakers are blown so i plan on installing new ones but wasn't sure what kinds would be best Im looking for some strong base without having to get subs, Any suggestions? Would i also have to get a new amp for these? any help is really appreciated i know these are probably some rookie questions. Thanks Nick.
  2. #2 Re: Speaker questions
    Are you using a harness that ties into the Monsoon amp wiring, or are you bypassing that and hooking your speakers directly up to your headunit? People will be able to elaborate more with a little more info.
  3. #3 Re: Speaker questions
    Jan 2012
    New York
    I'm honestly not sure i got installed at a shop
  4. #4 Re: Speaker questions
    GTP Level Member simbah's Avatar
    Lala land
    Go back to where you had it installed and tell them your problems, if they are reputable they will and should fix any issues no questions asked, if not I would look into tearing it apart and see how it is hooked up and what harness was used and then maybe the forum can help you out.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  1. Monsoon System - What ohm speaker do I need for the center dash speaker?
    By Schmitty in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 07:01 AM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  3. Speaker ?
    By kassel98gt in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2009, 05:53 PM
  4. Speaker Help
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2008, 11:36 PM
  5. New speaker help
    By 98gpgt98 in forum Audio, Security & Visual Electronics
    Last Post: 06-29-2008, 10:37 PM
