All following information listed is for a 04 N/A, It should remain the same for all 2004+ Naturally Aspriated or Supercharged applications. If any errors or variances are found please contact me via PM to have the information corrected.
Pressure, Vacuum and Temperature
Compression Check
The lowest reading should not be less than 70 percent of the highest reading.
No cylinder reading should be less than 689 kPa (100 psi) .
Computers and Control Systems
Engine Oil Pressure
Oil Pressure - 1850 RPM 414 kPa 60 psi
Fuel Pressure
Fuel Pressure (Key ON Engine OFF) 380-410 kPa (55-60 psi)
Fuel Pump
Power Steering Pump
Thermostat, Engine Cooling
Temperature Range 87 °C (188 °F) and 97 °C (206 °F)
