Thread: instrument cluster change out to a gxp
Results 1 to 6 of 6
tankrc instrument cluster change out... 12-06-2011, 06:08 PM
boostedcompg Re: instrument cluster change... 12-06-2011, 07:51 PM
michaelbm Re: instrument cluster change... 12-06-2011, 09:51 PM
tankrc Re: instrument cluster change... 12-06-2011, 10:25 PM
michaelbm Re: instrument cluster change... 12-07-2011, 07:07 AM
tankrc Re: instrument cluster change... 12-07-2011, 06:04 PM
  1. #1 instrument cluster change out to a gxp
    SE Level Member tankrc's Avatar
    warren, ohio
    Is it possible to use a 07 GXP instrument cluster in a 07 GT with v6? I wasn't sure if communication is different? Does need be recalibrated to my car?
  2. #2 Re: instrument cluster change out to a gxp
    utah
    plug and play my friend
  3. #3 Re: instrument cluster change out to a gxp
    New Brunswick
    Just like stated above, Plug and play and enjoy the upgrade...dont matter if you put in a canadian or American they will all work accordingly as well.
  4. #4 Re: instrument cluster change out to a gxp
    warren, ohio
    Will change the miles on the odometer in the DIC?
  5. #5 Re: instrument cluster change out to a gxp
    New Brunswick
    Nope the mileage in the DIC will remain the same.
    Mileage is stored in the DIC, and maybe the BCM as a backup should the DIC fail and a new one need to be programmed with the correct mileage.
  6. #6 Re: instrument cluster change out to a gxp
    warren, ohio
    thanks I be putting it in whaen i get it
  1. 04+ Instrument Cluster Wiring
    By nebgrandprix in forum Audio, Security & Visual Electronics
    Last Post: 05-24-2011, 09:43 AM
  2. 88 instrument cluster
    By jjhudecek in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2011, 03:09 PM
  3. Instrument Cluster (Odometer)
    By drall in forum General Tech Discussion
    Last Post: 09-13-2010, 09:07 AM
  4. instrument cluster lights
    By fasttmaxx in forum General Tech Discussion
    Last Post: 10-31-2009, 05:54 PM
  5. instrument cluster
    By 97detgp in forum General Tech Discussion
    Last Post: 06-01-2009, 09:57 AM
