Thread: Popping noise???
Results 1 to 9 of 9
  1. #1 Popping noise???
    SE Level Member biggd1980's Avatar
    Feb 2013
    Iowa
    My 04 GT2 recently developed a popping noise that I hear when back out of my driveway and at lower speeds, mostly when braking and accelerating. I just replaced the wheel bearings and the passenger side CV axle in the front (driver side CV replaced not too long ago), and the noise is still there. I was thinking maybe it's the sway bar links. Any ideas?
  2. #2 Re: Popping noise???
    Could be sway bar links or ball joints. Get under there and look around. It's easier for you to do that then for us to guess over the interwebz.
  3. #3 Re: Popping noise???
    Feb 2013
    Iowa
    I think I'm going to rule out sway bar links. Forgot those were just changed in February. As soon as I get a chance will inspect the ball joints.
  4. #4 Re: Popping noise???
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    Mines been doing this also. Subscribed.
    2003 Pontiac Grand Prix GTP, thrasher intake, intense poly upper mounts, 06+ Impala dual piston calipers, 88k miles
  5. #5 Re: Popping noise???
    Jun 2012
    mesa az
    Just found my popping. Try taking off the diagonal braces, and going for a drive then if it quits put them back on and torque the crap out of them
  6. #6 Re: Popping noise???
    Feb 2013
    Iowa
    That was it! I cannot believe it. Makes sense now that I think about it. The noise started right after I had to remove the brace to change the battery a few weeks ago.
  7. #7 Popping noise???
    Jun 2012
    mesa az
    Quote Originally Posted by biggd1980 View Post
    Awesome!! Glad it was that easy for you also.
    I couldn't believe it on mine either. My friend works on police cars for the county, and is quite familiar with impalas. So he brought that up the other night so I figured I'd give it a shot, and low and behold it worked
  8. #8 Re: Popping noise???
    Sep 2013
    Colorado Springs, CO
    Same thing happened to me, took weeks to figure it out.
  9. #9 Re: Popping noise???
    Buffalo NY
    Do you feel it in the brake pedal or the steering wheel? These cars have really crappy intermediate shafts that loose the lubrication thus causing the pop noise/feeling when youre turning and braking/acceleration.
  1. popping noise when turning right?
    By tichota126 in forum General W body
    Last Post: 03-24-2013, 04:28 PM
  2. Engine Popping Noise at 6K RPM
    By fendertele62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2012, 01:30 PM
  3. popping noise
    By ohagen383 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2011, 08:53 AM
  4. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  5. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
