Thread: How do I remove the dash board? Need help
Results 1 to 13 of 13
crazybrownklick How do I remove the dash... 12-04-2011, 04:15 PM
Explicit_Spade Re: How do I remove the dash... 12-04-2011, 04:16 PM
Curt7 Re: How do I remove the dash... 12-04-2011, 04:55 PM
Explicit_Spade Re: How do I remove the dash... 12-04-2011, 04:57 PM
lambokit Re: How do I remove the dash... 12-04-2011, 06:12 PM
lambokit Re: How do I remove the dash... 12-04-2011, 06:35 PM
Mad Monkey Re: How do I remove the dash... 12-04-2011, 06:42 PM
crazybrownklick Re: How do I remove the dash... 12-04-2011, 07:43 PM
Explicit_Spade Re: How do I remove the dash... 12-04-2011, 07:44 PM
lambokit Re: How do I remove the dash... 12-04-2011, 08:55 PM
1996pontiac Re: How do I remove the dash... 06-17-2012, 08:18 PM
gtpeddie Re: How do I remove the dash... 06-17-2012, 08:27 PM
Mad Monkey Re: How do I remove the dash... 06-17-2012, 10:48 PM
  1. #1 How do I remove the dash board? Need help
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I'm having trouble taking the dash panel off can somebody help on some steps to removed thanks.
  2. #2 Re: How do I remove the dash board? Need help
    Omaha, NE
    What exactly are you trying to do?
  3. #3 Re: How do I remove the dash board? Need help
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    If your talking about the front panel it just pulls straight off, don't be afraid to use force!
    2003 Grand Prix GT
  4. #4 Re: How do I remove the dash board? Need help
    Omaha, NE
    04+ section bruh.
    Gotta gently pop off the key surround first. But that's just the center stack, he is asking about the whole dash board... Which is why I asked what the is trying to do.
  5. #5 Re: How do I remove the dash board? Need help
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Hang on. I have the complete dash removal for 04+ somewhere. I will fund and post it.
    Lambokit to be built!!!!!
  6. #6 Re: How do I remove the dash board? Need help
    Apr 2009
    Radford, Virginia
    OK, I just posted the complete ALLDATA pdf file in the 04+ section. It's simply listed as 04+ Dash Removal. I have remove a complete 05 Dash and all. I stripped a complete 05 GTP. So if you have a question feel free to ask. Good luck.
  7. #7 Re: How do I remove the dash board? Need help
    London Ont, Canada
    yeah whats a "Dash board"? like the cluster area? stereo area? the whole entire dash?
    need specifics.
  8. #8 Re: How do I remove the dash board? Need help
    May 2011
    El paso tx
    Yeah im trying to remove the intire dash. Need some tips... Labokit couldnt see the dash removal.
  9. #9 Re: How do I remove the dash board? Need help
    Omaha, NE
    You have to have adobe to open the pdf. Its got all the info you need straight from alldata.
  10. #10 Re: How do I remove the dash board? Need help
    Apr 2009
    Radford, Virginia
    If you want I can email it to you. But as stated above: you will need adobe reader on your computer. It's a free download you can get.
  11. #11 Re: How do I remove the dash board? Need help
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    Anybody have a way to take the dash out of a 99 gtp for the radio?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  12. #12 Re: How do I remove the dash board? Need help
    Jan 2012
    Philadelphia
    Quote Originally Posted by 1996pontiac View Post
    dash trim? pull out the cup holders, pull off the shifter trim. then tilt the steering wheel all the way down pull the shifter back, and pull off the trim there just clips holding it in. might not even need to take out the shifter trim, i forget.
  13. #13 Re: How do I remove the dash board? Need help
    London Ont, Canada
    Can be done without taking out shifter trim. Just pop off the whole bezel. Really easy
  1. How to remove dash cover in 04+ Gp
    By kharma1 in forum General Tech Discussion
    Last Post: 08-01-2012, 01:01 AM
  2. Dash board lighting
    By rakarnsunju in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2011, 01:25 PM
  3. How to remove my dash?
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 05-27-2010, 08:12 PM
  4. New to the Board
    By Gibbster in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 10:55 AM
