Thread: gxp intake on 3800
Results 1 to 14 of 14
  1. #1 gxp intake on 3800
    Oct 2011
    AZ
    Will the k&n aircharger kit also fit the 3800?
  2. #2 Re: gxp intake on 3800
    SWPA
    Even if it did its not really worth the money.
    I am spending more than most on my low budget intake and still will only have about $60 into it including couplers, polished pipe, and the filter. And mine is going to flow better than he K&N one.
  3. #3 Re: gxp intake on 3800
    SE Level Member KirkpatrickJTK's Avatar
    Oct 2011
    Urbandale, Ia
    If you are wanting good bang for your buck honestly I would check out an ebay seller by the name of ChromeIntakes I purchased mine from them and its absolutely worth the 60bucks I have included the link to their page on ebay.
    eBay My World - chromeintakes
  4. #4 Re: gxp intake on 3800
    And your sure it's going to flow better? More of a opinion huh? how? K&N intake is a great intake not worth the money brand new but finding a used one for around $100 is a steal and well designed. Get the one designed for the 3800 and not the GXP doubt it would fit w/o modification. 2 different engines.
    04 Comp G.
  5. #5 Re: gxp intake on 3800
    SWPA
    I guarantee its going to flow better. The filter I will be using is proven to flow better, and it was proven using almost the exact same type of flow machine that K&N displays at auto parts stores.
    Green Filter USA Flow Machine - YouTube
    There's no trickery, no special effects. The Green Filter is made directly at our factory, the K&N is bought directly from K&N and the paper filter is bought directly from a local auto parts store.
  6. #6 Re: gxp intake on 3800
    Yea...that video proves absolutely nothing other then that particular filter flows better then the so called K&N in the video that's all. There's so many thing that factory into the intake other the filter. For example the bend/heat/ etc and it's not like you can't replace the filter w/ something different.
    04 Comp G.
  7. #7 Re: gxp intake on 3800
    SWPA
    Its a simple bend and it larger than the K&N tube. If you want to spend $300 on a K&N intake then you may as well use some money as toilet paper while you are at it.
    And that is called a FLOW machine so the filter I am going to be using FLOWS better than K&N. You asked the question, I answered it.
  8. #8 Re: gxp intake on 3800
    Homemade intakes on a 3800 v6 work the same as any of the cold air intakes on the market, its been dyno proven that the $200+ intakes make no difference from an open cone. http://www.grandprixforums.net/dyno-...ake-33225.html Save yourself some money and just make your own intake.
  9. #9 Re: gxp intake on 3800
    West Side Michigan
    If you spend $300 for an intake you're stupid. Plain and simple.
    What is an intake? A filter and pipe that leads to the throttle body. What are the other factors leading to making a better intake??? Can't believe some people actually stand by the k&n intake system when they can make the same thing for $50...
    At the end of the day it's just a stupid intake and you won't make a crazy amount of power out of it.. so why throw $300 towards something you'll barely notice? Might as well invest in a tune.
  10. #10 Re: gxp intake on 3800
    Agreed. I stated earlier that if you find a used k&n for $100 its well worth it. I would spend $300 on it because there are cheaper alternatives. Build quality is there I went from a crappy Wizair to k&n couldny been happer and yes i bought it used for the low.
    04 Comp G.
  11. #11 Re: gxp intake on 3800
    A used $100 K&N is still $50+ more dollars than I'd spend on any 3800/5300 intake system.
  12. #12 Re: gxp intake on 3800
    Bunnell, FL
    /thread
    I'm a Sex Offender
  13. #13 Re: gxp intake on 3800
    ^^Needs bigger filter.
  14. #14 Re: gxp intake on 3800
    Oct 2011
    AZ
    Quote Originally Posted by z3r0 View Post
    /thread
    Lol well that's not really what I had in mind but it works.
  1. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  2. 98 3800 GT to Supercharged 3800 ?'s
    By jsavi85 in forum General Tech Discussion
    Last Post: 07-28-2010, 07:43 AM
  3. 3800 vs 3800 Supercharged
    By extreme in forum General Tech Discussion
    Last Post: 07-31-2009, 10:45 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
