Thread: Traction Control Won't Shut Off
Results 1 to 20 of 27
  1. #1 Traction Control Won't Shut Off
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I picked up an '06 GT about 2 months ago, and with all of the snow since then, there is something that I've noticed. When my traction control kicks in, I can't seem to shut it off. I can press the TC button all I want, and it never shuts off.
    For general driving, this is OK as it helps to keep things under control, however, there are times when I want to get up and moving so to speak, and if there is the tiniest bit of moisture or snow under the tires, even if it is just a small patch of it, traction control kicks in and I sit there puttering along until I get enough speed going that it shuts itself off and then the RPMs finally get up there, boost kicks in, and off I go.
    Personally, I am good with traction control off ALL off the time. I have so much experience driving in snow/ice that I know when to apply power and when not to that I don't need the car trying to control it.
    So what could be wrong? Why can't I turn it off?
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  2. #2 Re: Traction Control Won't Shut Off
    Troy OH
    are you letting out of the throttle copletely when it kicks on? usually it stays lit up and keeps cutting fuel or whatever it does until your foot is completely out of it
  3. #3 Re: Traction Control Won't Shut Off
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Press firmly and hold for i think 3-5 seconds, mine doesn't shut off sometimes
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  4. #4 Re: Traction Control Won't Shut Off
    Apr 2008
    Marion, Iowa
    If I let off the gas, it shuts off, but if I keep the pedal down, it stays on and limits fuel/rpms and prevents wheel spin (like it is supposed to)...
    I just want to be able to push the button and disable it like on my 2000 GTP that I used to have.
  5. #5 Re: Traction Control Won't Shut Off
    Spring Lake, Mi
    you can push the button and hold it
  6. #6 Re: Traction Control Won't Shut Off
    Apr 2008
    Marion, Iowa
    Yeah, I will have to try that... I think that I've tried holding the button, but maybe just a full second or two. I will try a little longer.
    Thanks!
  7. #7 Re: Traction Control Won't Shut Off
    Apr 2008
    Marion, Iowa
    Hmm... I tried to just hold down the TC button and nothing happened after about 10 seconds. Then I waiting until I got to a spot with a lot of packed down snow/ice, hit the gas to trigger the Traction Control, and pressed the TC button. I held it down for at least 4 seconds and it never shut off...
  8. #8 Re: Traction Control Won't Shut Off
    GTX Level Member Confusingboat's Avatar
    Minnesota
    You shouldn't have to hold it -- at least I don't have to. As soon as you turn the car on press the button. A message should come up saying Traction Control Off and the traction control light should light up on the dash.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #9 Re: Traction Control Won't Shut Off
    GT Level Member donmega's Avatar
    St louis, mo
    ok mine does the same thing I thought to hold it down and started pressing the button violently frustrated. then it all of a sudden turned off. (Im the same way id rather be in control in snow). I realized that if you press it down and give it a wiggle it shut off. I think the button isnt aligned right. give that a try press it down and wiggle around
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  10. #10 Re: Traction Control Won't Shut Off
    Minnesota
    If all else fails just buy a new button. They can't be that expensive.
    2015 Evo MR
  11. #11 Re: Traction Control Won't Shut Off
    Troy OH
    maybe the owners manual? lol
  12. #12 Re: Traction Control Won't Shut Off
    Spring Lake, Mi
    hold the brakes when you do it, I a couple times in the past couple days and i think the brakes need to be pressed. reverse donuts ftw!
  13. #13 Re: Traction Control Won't Shut Off
    Apr 2008
    Marion, Iowa
    OK. So I pressed and wiggled the button a few times, and it turned off. Wiggled a little more and it turned back on. Now it works every time. I am thinking that there must have been some junk in the button that I managed to wiggle loose.
  14. #14 Re: Traction Control Won't Shut Off
    St louis, mo
    Quote Originally Posted by nickbuol View Post
    thats funny. told ya worked for me
  15. #15 Re: Traction Control Won't Shut Off
    Minnesota
    Probly the dumbass previous owner spilling pop or coffee all over and never using the TCS button.
    2015 Evo MR
  16. #16 Re: Traction Control Won't Shut Off
    Ocala, FL
    I've never had abs or tcs, one of my sensors are broken. Makes it easy that way, and survived a winter in Alaska without any problems, on all season tires.
  17. #17 Re: Traction Control Won't Shut Off
    Spring Lake, Mi
    My button worked great when the car was warm today, I didn't have to hold it or anything
  18. #18 Re: Traction Control Won't Shut Off
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    GM has abuse maagement built into the pcm and ecm that will over ride that button. Try doin a burn out on dry pavement, it may let the tires turn over a few times but thats it. I knew of guys that would try to override it by unpluggin their abs module not allowing the computer to read tire speed but it's only a temp fix, plus your DIC goes nuts and it can throw your car into limp-home mode. A tune was the only way I could get the GXP to release its grip on the world. JME
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  19. #19 Re: Traction Control Won't Shut Off
    GT Level Member 05CompG's Avatar
    Arizona
    I believe it is something with these buttons and the circut because about 90% of the 04+ GP Owners i have come in contact with have this issue...mine works sometimes and others it doesnt. i have to press it a trillion times to get it off.
    Her Name...Stacii Dash
  20. #20 Re: Traction Control Won't Shut Off
    Minnesota
    Trace the wires back and look for a weak spot then?
    2015 Evo MR
  1. traction control
    By rodburner in forum General Tech Discussion
    Last Post: 07-06-2011, 08:38 PM
  2. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  3. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
  4. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
  5. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
