Thread: Traction Control Won't Shut Off
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Traction Control Won't Shut Off
    Donating Users NoBoost91's Avatar
    Queens, New York
    i had the same problem, it was just the switch, picked up a new one at the dealer and it worked fine ever since
  2. #22 Re: Traction Control Won't Shut Off
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    x2^. they get dirty where there located. could probably remove the top of the button and clean the junk out.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  3. #23 Re: Traction Control Won't Shut Off
    GT Level Member RotyP's Avatar
    Tn
    So how do you remove the button or get to its underworkings?
    2007 Grand Prix GT - 20% Tint, Red Inlays
  4. #24 Re: Traction Control Won't Shut Off
    GTX Level Member Confusingboat's Avatar
    Minnesota
    By removing the center console.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  5. #25 Re: Traction Control Won't Shut Off
    SE Level Member 2007gp's Avatar
    Apr 2011
    ontario, Canada
    had same problem with a 07 i took the top of the button out with a small flat head cleaned out all the crap around it works perfect now thanxs!!
  6. #26 Re: Traction Control Won't Shut Off
    Apr 2011
    ontario, Canada
    on going problem in my car the location of the button is beside the cup holder right? **** gets into the switch and screws it up, i just finished moving mine only took about an hour. buy a basic push button contact switch remove the gear select lever handle then center console, 4 bolts beside seats, pull hard on the back unclip wiring harness c. console will come out if the back touches the roof u may need 2 ppl. the brown and the black wire are the ones you want the grey and black is for the light, 2 wks later still dosnt shut off sometimes in the morning?
  7. #27 Re: Traction Control Won't Shut Off
    Minnesota
    Or you can just put the car in gear to get the shifter back farther lol
    2015 Evo MR
  1. traction control
    By rodburner in forum General Tech Discussion
    Last Post: 07-06-2011, 08:38 PM
  2. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  3. Traction Control
    By Dewey1964 in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 11:06 PM
  4. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
  5. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
