Thread: Gauge Cluster Not Working
Results 1 to 13 of 13
  1. #1 Gauge Cluster Not Working
    St. Cloud, MN
    I was driving home last night and about 20 min into driving all my gauges stopped working except my MPH gauge. My gas, temp and RPM gauges don't move and stay at the bottom, as if the car is turned off? But My MPH gauge works just fine? Also, my DIC just says error on everything I try to look at?
    Thanks for any help.
  2. #2 Re: Gauge Cluster Not Working
    Its happened on my car and if you google search it comes up. Do you have a remote start? Cause thats why mine was doing it, never found a cure cause it stopped, except to turn off the car, clear the messages on the DIC, open the door, close the door and restart the car, that seemed to get it to stop.
  3. #3 Re: Gauge Cluster Not Working
    St. Cloud, MN
    Yes, I have remote start, but I never used it the day it started doing this. It did it again the other day, but hasn't again since. Still trying to figure out why it's been doing this and I can't seem to get a definite answer.
    Thanks Drunkie.
  4. #4 Re: Gauge Cluster Not Working
    Donating Users NoBoost91's Avatar
    Queens, New York
    My car did this a few times too and I don't have a remote start as drunkie said shut the car off and they start working again , I thought it might have been a fuse but since it hasn happend in like 6 months I never bothered to find out
  5. #5 Re: Gauge Cluster Not Working
    Yeah its a wierd fluke, but it only comes up for the Grand Prix on Google...its strange no real answer or solution from what I can see
  6. #6 Re: Gauge Cluster Not Working
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Mine did the same thing one day while I was driving on the freeway in the rain. I pulled over and checked my fuse box and it turns out my radar detector wire had come unplugged and was causing a short. Hasn't happened since then.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  7. #7 Re: Gauge Cluster Not Working
    Nov 2009
    Grand haven
    come unpluged from where? ^^ How did you have it wired in?
  8. #8 Re: Gauge Cluster Not Working
    St. Cloud, MN
    ^I'm guessing he wired the red positive wire into one of the 10 amp fuses.
    I have my LED tube lights wired into one of the 10 amp fuses in my car too so maybe that's why it did it?
  9. #9 Re: Gauge Cluster Not Working
    Minnesota
    He is correct. Since I don't have OnStart I just used that empty slot. It happened like a year and a half ago though so I can't remember exactly what came unhooked from where. I think the ground came undone and touched something else in the fusebox cause I use that big metal piece with a hole for a ground. I now have two huge washers there though so that ***** ain't movin lol.
    2015 Evo MR
  10. #10 Re: Gauge Cluster Not Working
    SE Level Member 05CompGMan's Avatar
    Jul 2011
    CT
    I'm having this damn problem too. All gauges stop working except speedo. DIC works too but only after you clear the messages about low fuel and check traction control. Anyone find a fix for it yet? I am having the long cranking problem too on start up but only after it has been running for a bit. I am going to try and replace the crank sensor to see if it helps.
    If anyone has come up with any other ideas for this fix please chime in.
    Thanks!
    05 Comp G - XP Cam // 3.4 // WBS Headers // Spectre Intake // Overkill PCM // PRJ Wires // AL104's
  11. #11 Re: Gauge Cluster Not Working
    Enfield, CT
    wonderful.... I'm at this point and there is no fix.....
  12. #12 Re: Gauge Cluster Not Working
    GXP Level Member
    Mar 2015
    Tomball
    What type of interface do you guys have for your remote start? Is it the old key wrapped in wire trick ir do you have a separate data bus module that connects to the car without having to use a spare key?
    Jeff
  13. #13 Re: Gauge Cluster Not Working
    May 2012
    Where winter never ends
    Explanation Time -- There are three reasons for this:
    1) 04-05 databus can get flooded, they are under very heavy load, adding a remote start can piss this system off very easily. Even one small bit error in a command on the bus can cause a total melt down like the car is a ****ing 3 year old that wants ice cream and mommy wont give it.
    2) Aftermarket radio, believe it or not the radio has a data line on the CAN bus, this data line feeds the DIC the date, but it also seems it does more. When the radio is removed this data line is now gone, the car will ask hey radio whats up, the radio doesn't respond, the car goes YO RADIO?! and then the car has a total melt down like the car is a ****ing 3 year old that wants ice cream and mommy wont give it.
    3) There was something about corrosion on the BCM and PCM pins and several other connectors causing fluctuating signals causing more meltdowns.
    I have heard rumors that by switching to a 5 button DIC can fix these issues in some instances depending on the root cause, the radio issue can be resolved by installing the radio in the trunk and running the data line back to it.
    2000 Regal - Winter Beater
  1. Gauge cluster
    By monsterjam5000 in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2010, 09:04 PM
  2. Gauge Cluster
    By lstexan in forum General Tech Discussion
    Last Post: 04-23-2010, 11:13 AM
  3. Working on a digital gauge cluster project...
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 09-22-2009, 02:53 PM
  4. Gauge Cluster
    By boy1dur in forum General Tech Discussion
    Last Post: 09-02-2009, 06:52 PM
  5. gauge cluster lights.
    By 0LmtdGP3800 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2009, 03:40 PM
