Thread: PLEASE HELP ME! electrical problems
Results 1 to 4 of 4
  1. #1 PLEASE HELP ME! electrical problems
    pharr
    hello i have a 2006 grand prix gt bought about 9 months ago tuned it three times full boltones e85 ran a 13.3 2 weeks later i take it bake to the track and it ran like ****
    i got maf code or map
    replaced both and the car did the same time
    it misfires in high rpm
    i get a blinking cel
    my history of codes since the problem
    p0171
    p0107
    u0107 ???
    p0306
    p0116
    i am guilty of pouring water on the motor to cool it down before a race a couple of times people say that could of shorted it out
    but hurrs my expierence
    my fuel pressure drops from 60 to 58 ok i know that bad but i dont think that is enough to mess me up so bad
    i am starting to belive its the wiring harness or the ecu
    HURR THE WIERD PART!!!
    ok so i conect a scan tool up to the computer at idle
    it says 1.61 to 2.08 somthing/m
    and the caclated load is 49 % with ac at idle
    i have swapped 3! yes 3 maf sensors and the all have the same reading
    i step the gas in park and the calc idle drops to 34% to 29%
    ok so i test the 5 volt referecne wire that connects to the ecu
    it 5.003 volts with the car off with the key forward i plug the maf and it drops to 2.5 i go to 3000 rpms in park and the voltagle fulcuates be tween 2.4 and 2.6 should it go up????
    yes all three mafs have the same reading
    the car can feel great ill get up and go fast!
    the i turn it off and it will runn like a old tired dogg
    i bought the pcm from zzp about 7 months ago
    please help me i am so stumped!!!!
  2. #2 Re: PLEASE HELP ME! electrical problems
    GT Level Member Hawkins04's Avatar
    Ga
    the p0171 is a too lean bank 1 code and can be alot of things. i would first check the intake and make sure everything is tight.
    Wouldn't You Like To Know
  3. #3 Re: PLEASE HELP ME! electrical problems
    pharr
    Quote Originally Posted by Hawkins04 View Post
    but what about my u0107 code lost communcation with throttle body
    i have gone into engine powered down mode
    also the voltage off my maf goes crazy legs on me
  4. #4 Re: PLEASE HELP ME! electrical problems
    Ga
    i am not sure about that
  1. A/C Electrical Problems
    By ryanrice in forum General Tech Discussion
    Last Post: 05-24-2010, 10:43 PM
  2. Electrical problems....
    By Max PowerX360 in forum General Tech Discussion
    Last Post: 04-02-2010, 11:50 AM
  3. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  4. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
  5. i think im having electrical problems...
    By 2000GTP in forum General Tech Discussion
    Last Post: 01-17-2009, 08:36 PM
