Thread: Cracked upper motor mount bracket
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Cracked upper motor mount bracket
    SE Level Member AntonyJ1214's Avatar
    Newport News, VA
    So I don't need another one of those aluminum brackets again?
  2. #22 Re: Cracked upper motor mount bracket
    Not if you plan on getting a supercharged coil pack bracket...they aren't aluminum.
  3. #23 Re: Cracked upper motor mount bracket
    Newport News, VA
    So I won't need the aluminum part again? Here is what I have now....
  4. #24 Re: Cracked upper motor mount bracket
    Newport News, VA
    I guess now I gotta find a supercharged one..... This won't be fun.
  5. #25 Re: Cracked upper motor mount bracket
    i found mine on a 97 N/A olds intriuge.
    Be sure to sand it and give it a couple coats of rustcheck paint.
    Keep it nicer looking for longer.
  6. #26 Re: Cracked upper motor mount bracket
    Milwaukee,WI
    Glad to know that I'm not the only one with this issue. I hate to pay the dealer $83 for this bracket. Does anyone know an aftermarket site and what is the exact name of the part?
    Appreciate the help.
  7. #27 Re: Cracked upper motor mount bracket
    its the coil bracket.
    Its a factory part, not sure how an aftermarket site would be able to help you much considering most yards only sell it with the engine.
    I got mine and some other stuff for $20 whereas another yard I called wanted closer to $100 for it.
    You could try searching classifieds on 3800 sites to see if anyone has one for sale though.
  8. #28 Re: Cracked upper motor mount bracket
    Newport News, VA
    Did any other than supercharged GPs have this coil bracket? Or just the SC ones?
  9. #29 Re: Cracked upper motor mount bracket
    Quote Originally Posted by That Canadian Guy View Post
    It seems early series II would have the appropriate bracket.
  10. #30 Re: Cracked upper motor mount bracket
    Newport News, VA
    does anyone have a part number for said bracket?
  11. #31 Re: Cracked upper motor mount bracket
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    shouldn't be over 10 bucks at pullapart... I get them all the time and resell or powdercoat them and sell. Any l67 should have it if its in a wbody the ssei's don't IIRC
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  12. #32 Re: Cracked upper motor mount bracket
    Jul 2008
    Tampa, FL
    i want to say my buddy pulled mine off of an old bonneville or regal or something like that...
  13. #33 Re: Cracked upper motor mount bracket
    Iowa
    Is there anywhere online that i can find this mount? or do i need to go to a junkyard or something? one of the ears broke on my mount, likely from the previous owner over tightening it.
  14. #34 Re: Cracked upper motor mount bracket
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Mine broke the exact same way and i just changed it for the 3rd time just a couple of months ago. I got it off a 99 or older GP GT, put some 100lb wire around it to help support it and its good so far.
    Not to hijack a thread or anything but the driver side bracket in the inside the black bushing thing cracked and made the driver side black thing ( i thinks its the dogbone) loose. Should i just get another one from a junk yard?
  15. #35 Re: Cracked upper motor mount bracket
    Texas
    ^ more like bringing a thread back from the dead.
    The black thing is the bushing in the dog bone. They will wear out eventually and can be purchased through a vendor. Or you could pull the dog bone if you want. You could just upgrade to shorter dog bones for like $40 from ZZP, or spend the coin on the billet ones.
    85 Corvette
    01 TA
    03 Z06
  16. #36 Re: Cracked upper motor mount bracket
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by txslow6 View Post
    True i did not pay attention to the date
    Thanks for clearing that up and ya i think i might just pull one from the junk yard, thanks.
  17. #37 Re: Cracked upper motor mount bracket
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    I hope this helps somewhat, i did this last weekend
    http://www.grandprixforums.net/upper...ket-60192.html
  18. #38 Re: Cracked upper motor mount bracket
    Apr 2012
    Quote Originally Posted by Ibwrong View Post
    It seems to happen alot on the aluminum brackets, I thought they switched over to the cast brackets on anything from 01 and up.. Back in the day we thought it was the motor mounts or tranny mounts.. Hell we replaced them and busted that bracket again... Finally just said screw it and put the cast bracket on from the GTP's... I know of atleast 4 GP GT's that had this just in OKC.
    i replaced my aluminum one n cracked it back in half again. i was told it wasnt mounted back on right but i see that the reinstallment wasnt the issue. it is just the part. my pontiac is 2002
  1. Installing upper poly motor mounts?
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 10-12-2010, 11:10 PM
  2. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  3. upper motor mount help please
    By Red_GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 01:28 PM
  4. Motor mount help for 94 GP
    By 954mula in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-07-2008, 12:02 AM
