Thread: help with pulley size?
Results 1 to 20 of 23
  1. #1 help with pulley size?
    SE Level Member benblank's Avatar
    WI
    Helping my brother mod his 04 Comp G and we cant decide on which pulley to go with?
    Car will have SSAC headers, Catback, FWI, PCMforless tune, Autolite 104 plugs.
    I have been told that with the newer supercharger the pulley changes are more drastic when compared to the older superchargers? After we are done with the mods we are currently working on that will be as far as the car goes.
    After reading all the stuff in the forums I am thinking we are looking at the 3.4 or the 3.5" pulley. I will scan the car with autotap to be sure its not pulling timing but would like to pick the right pulley off the bat.
  2. #2 Re: help with pulley size?
    GTX Level Member killakross5o4's Avatar
    illinois
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  3. #3 Re: help with pulley size?
    swift current,sask.
    yep 3.5 should be a good setup.
  4. #4 Re: help with pulley size?
    Norristown, PA
  5. #5 Re: help with pulley size?
    illinois
    3.6 is better
  6. #6 Re: help with pulley size?
    WI
    Originally we were looking at the 3.5" don't we have enough mods to be safe on the 3.5?
  7. #7 Re: help with pulley size?
    illinois
    what tune u got
  8. #8 Re: help with pulley size?
    WI
    Quote Originally Posted by killakross5o4 View Post
    what tune u got
    Was going to get a tune from pcmforless. They tuned my LT1 and did an awesome job.
  9. #9 Re: help with pulley size?
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by benblank View Post
    are they located in NC by chance? i was recomended a tune from them by a performance shop in town where i live.
    02 GTP with mods 05 GP for DD
  10. #10 Re: help with pulley size?
    WI
    PCMforless.com
  11. #11 Re: help with pulley size?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    3.6 ud be safer
  12. #12 Re: help with pulley size?
    illinois
    i personally never heard of them...have you read the saflty modding your 3800 thread
  13. #13 Re: help with pulley size?
    Norristown, PA
    Can you scan for KR? that will let you know if you can run the 3.5" safely
  14. #14 Re: help with pulley size?
    youre better off running a 3.6 with more timing than a 3.5 or 3.4 with less timing.
  15. #15 Re: help with pulley size?
    Jul 2008
    yep thats them... not far from me at all.
  16. #16 Re: help with pulley size?
    Charles City, IA
    I would run a 3.6 and lots of timing.
    SMGPFC Two Nipple General
  17. #17 Re: help with pulley size?
    MO
    3.6 again
    <brandonl2000> LMAO D!!
  18. #18 Re: help with pulley size?
    WI
    Where can I get the 3.6" pulley, ZZP only sells the 3.5" and smaller? Also which belt will I need?
  19. #19 Re: help with pulley size?
    illinois
    stock belt
  20. #20 Re: help with pulley size?
    May 2008
    McHenry IL
    get a 2.8 lol jk
  1. pulley size
    By hollis1 in forum Introductions/Noob Questions
    Last Post: 12-16-2009, 12:14 PM
  2. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
