Thread: how bad is tapshift?
Results 1 to 5 of 5
  1. #1 how bad is tapshift?
    GT Level Member BoostedComp's Avatar
    Youngstown
    i have it on my comp g and use it occasionally. id say maybe 40% of the time. i seen a thread with people sayin it beats up the tranny. how bad is it? should i avoid using it? is it just bad when beating through the gears or all together as i use it sometimes to just get good milage by keeping the revs low. thanks for the input
  2. #2 Re: how bad is tapshift?
    Michigan
    Its all in the electronics. Your tranny is already Electronicaly controlled. Any harm would come from frequent shifts both ways when there isnt a need or anything else that would cause wear and tear.
    I have always been easy on my car so I have no need to use it but somtimes I do.
    08 GXP all stock
  3. #3 Re: how bad is tapshift?
    Banned - Busted For Scamming
    Feb 2009
    there is nothing wrong with using tapshift. it controls the electronic portion of the tranny, therefore there is nothing different about using tapshift vs. the computer controlling shifts. its not like putting it in manual low and shifting, as different components are engaged then and damage could result as there are different members holding components at that point.
  4. #4 Re: how bad is tapshift?
    Michigan
    Ive been too scared to try. But I have heard that the tap shift allowed for slightly higher revs.
    08 GXP all stock
  5. #5 Re: how bad is tapshift?
    Youngstown
    alright thanks guys i appreciate it
  1. 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2009, 12:42 PM
  2. LS4 V8 DoD 4T65-E TAPShift info
    By Sinister Performance in forum 5.3L V8 (LS4)
    Last Post: 12-29-2008, 02:32 PM
