Thread: Does anyone know how to program keyless remotes?
Results 1 to 13 of 13
  1. #1 Does anyone know how to program keyless remotes?
    CT
    I need to replace mine and I found some on ebay but it says that you have to have the dealer or a locksmith program them.
    eBay Motors: 2005 2006 2007 PONTIAC GRAND PRIX TWO KEYLESS REMOTES (item 280314968403 end time Feb-24-09 09:43:17 PST)
  2. #2 Re: Does anyone know how to program keyless remotes?
    Aug 2008
    KCMO
    first off did you make sure you GM/L: numbers on the back matched?
    Untitled Document
    Try that and see if it works if not you may have to have a dealer program them
  3. #3 Re: Does anyone know how to program keyless remotes?
    lynn, ma
    i think my owners manual had the instructions- and it was easy as i recall
  4. #4 Re: Does anyone know how to program keyless remotes?
    lynn, ma
    if you want i can dig it up and look
  5. #5 Re: Does anyone know how to program keyless remotes?
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    x2 what carl said
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  6. #6 Re: Does anyone know how to program keyless remotes?
    Wausau, WI
    do a search as threads that I have been in already have this info...shouldnt be too hard to find
  7. #7 Re: Does anyone know how to program keyless remotes?
    GTX Level Member cerick08GP's Avatar
    I just had my FOBs reprogrammed a couple weeks ago. Basically a dealership has to do it, or possible a locksmith. But there are not many locksmiths who actually do it, so basically your back to option A. FYI it cost me $45, and it took them 30 minutes. Just for comparison pricing incase you do find a locksmith.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  8. #8 Re: Does anyone know how to program keyless remotes?
    Wausau, WI
    Quote Originally Posted by cerick08GP View Post
    you can do it yourself and it isnt that hard. there is something like a seven step process to do it...you start by pulling a fuse. you can do the whole process in less than five minutes. basically a series of commands by turning the key in the ignition and such...a dealer can do it , but many including myself have done it. After reading that you have an 05 I am unsure of the process for that year...so I apologize if I was incorrect. I do know that you can do that for the 97-03's for a fact though yourself
  9. #9 Re: Does anyone know how to program keyless remotes?
    This whole issue was discussed at length like two months ago. Get any 04-08 GP and program the remotes, post a video, then I might believe you. We had the same “opinions” posted before, same BS as now. Go ahead, it would make a lot of peoples day.
    Your secret procedure not posted anywhere, but it should be similar to an 03 or older.
    2008GP
    2002GP||sold
  10. #10 Re: Does anyone know how to program keyless remotes?
    Donating Users wulfpack06's Avatar
    KCMO
    97-03 only!!!!!!!!!!!!!!!!!!!!!
    IMPORTANT: Before entering programming mode, have in possession all of the remotes you
    will be useing on the vehicle. Once you program the remote. all previous remotes that were
    programmed will be erased from memory. The other remotes will not be functional until you
    program the them again.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    owner's manual to properly locate the "MALL PGM" fuse.
    4. Insert the key into the ignition, and turn to the ACC position.
    5. Turn the key to OFF and then back to ACC within 1 second.
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    programming mode.
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    synchronization. It is necessary to wait approximately 14 seconds for a second chime
    that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote
    04+
    There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote.
  11. #11 Re: Does anyone know how to program keyless remotes?
    Wausau, WI
    yep...that is what I thought and as further proof of you guys could have used the search feature:http://www.grandprixforums.net/f81/k...ing-22353.html
    This also determined that the procedure was for 03 and earlier...04's and up need to go to the dealer.
  12. #12 Re: Does anyone know how to program keyless remotes?
    Wausau, WI
    If you would have read the post right above yours I said it would work for sure for 97-03 only...I was unsure about the 04's and newer. In the initial post I did not notice the OP's year of car.
  13. #13 Re: Does anyone know how to program keyless remotes?
    New Brunswick
    04's have a work around if you know someone with an 00-05 impala, simply install your keyless reciever into a buddys impala and go through the programming procedure on the factory stereo, once done reinstall back into your grand prix and your good to go
    The reciever in the impala is under the left side of the windshield defroster trim, where as the 04 grand prix has it on the right side under the defroster trim.
    In 05 this place became the area for the available navigation antenna and the reciever moved near the bqack window.
    05's and up this wont work unfortunatly and have to be done through a dealer.
    Might seem like a lot of work, but really isnt and feasible if your dealer wants a rediculous amount of money just for programming.
  1. Did all 04 GP come standard with remote keyless entry
    By serenityacres in forum 04+ Specifics
    Last Post: 02-20-2009, 04:53 PM
  2. My keyless entry broke
    By biggmman in forum General Tech Discussion
    Last Post: 10-18-2008, 12:11 AM
  3. can anybody help me program my pcm
    By shawn in forum PCM Tuning
    Last Post: 08-09-2008, 11:51 AM
  4. program a fob??
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 07-07-2008, 10:22 AM
