Thread: 04 cat converter.
Results 1 to 5 of 5
  1. #1 04 cat converter.
    SE Level Member rcweldon988's Avatar
    Feb 2009
    Mass.
    Has anyone ever replaced the cat on and 04? My car has an p0420 code which is low cat efficiency. I allready changed my 02 sensor to see if it was the problem but it wasnt which means the cat is bad so im going to buy a new cat and change it myself, just seeing if anyone else has changed it and if its not a pain in the ass?
  2. #2 Re: 04 cat converter.
    Donating Users
    Deland, IL
    it'll have to be cut out and and the new on rewelded in
  3. #3 Re: 04 cat converter.
    Feb 2009
    Mass.
    I know that, Im just wondering how hard it is to do without a lift and just plain old car jacks.
  4. #4 Re: 04 cat converter.
    Donating Users
    Deland, IL
    you can do it with jackstands, but it will be harder. unbolt the downpipe and take it somewhere where they will weld it on for you
  5. #5 Re: 04 cat converter.
    Feb 2009
    Mass.
    Ok all I needed to know and I also have a welding machine in the garage so I can even do that myself. Thanks!
  1. bad converter again
    By shawn in forum General Tech Discussion
    Last Post: 02-16-2009, 03:11 PM
  2. Torque converter ?
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 04:47 PM
  3. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
  4. ZZP Converter doesn't line up ?
    By Meemperor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2008, 10:13 PM
