Thread: Looking for my maf airflow (32.54 lb/min) to hp conversion
Results 1 to 3 of 3
  1. #1 Looking for my maf airflow (32.54 lb/min) to hp conversion
    Nov 2020
    Baltimore
    My MAF Airflow rate with the mods listed below : 32.54 lb/min on a 60 degree day with 56% humidity, under hood inlet air averaging between 82-85 degrees at the MAF. Seeing 2.3 KR from 5700rpm to 6000rpm, with a slight blip of 4.0 from 5500-5700 initially. Any idea what my horsepower is based on that air flow number?
    I’m thinking somewhere around 290 crank hp. I -sort of- logged the data in a screenshot from my dash command app I use on iPhone (all extended PID’s were purchased). The screenshot won’t make any sense unless you completely 100% understand the layout of the Dash Commander data grid. I plan to get it dynoed but was just curious how accurate maf air flow to hp conversions are. Still on the stock 3.8 supercharger pulley, also this of course is a Gen V supercharger. Car has 198k on the engine and transmission. Thanks in advance and the current setup of the car as well as the screenshot, are shown below :
    2007 Pontiac Grand Prix GT Supercharged 4AT (Bolt Ons, Mildly Gutted, “First Draft” Edition)
    Changes to the car :
    4 Inch Inlet Intake Filter
    Autolite XP104 Iridium (-not- the normal copper 104's) plugs gapped to 0.050
    ZZP Alternator Power Cable
    ZZP 180 Degree Thermostat
    ZZP Polyurethane Dog Bone Bushings
    ZZP Polyurethane Upper Motor Mounts
    ZZP Aluminum Transmission Pan
    3 Inch Collector BHR Stainless Steel/Titanium Wrapped Headers
    3 Inch BHR Catless Downpipe
    3 Inch Catback w/ Cherry Bomb Glasspacks
    EGR Bypass
    TransGo Shift Kit
    93 Tuned by Daniel Smuts
  2. #2 Re: Looking for my maf airflow (32.54 lb/min) to hp conversion
    so its stock and some how now has 50 hp over stock? you would be lucky to have the 240 chp its advertised with being its got 200k on it already.
    that kr is not helping either. every degree of kr pulls 2 degrees of timing.
  3. #3 Re: Looking for my maf airflow (32.54 lb/min) to hp conversion
    GT Level Member mguzzo's Avatar
    Buffalo NY
    290 crank hp? Without a pulley change you haven't done a thing. the fact you're getting KR with headers tells me your timing and fueling are way off.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. 04+ power passenger seat conversion/ driver's fold conversion
    By wstefan20 in forum General Grand Prix Discussion
    Last Post: 04-04-2020, 01:15 PM
  2. GM 85mm LS6 LQ4 MAF Mass Airflow kit
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2017, 06:08 PM
  3. Airflow or radiator problem?
    By medicmandan in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-04-2015, 12:08 AM
  4. P0102 Mass airflow sensor
    By Guy with a Grand Prix in forum General Tech Discussion
    Last Post: 03-09-2013, 01:39 PM
  5. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
