Thread: No spark
Results 1 to 3 of 3
  1. #1 No spark
    Sep 2020
    GA
    Fellas I have a 04 GTP Comp G. Only mod is a ZZP PCM.
    One day wife driving to work and the car dies. It would not re-start (would crank/no spark). After sitting a bit it would fire right back up. It will drive approx. 15 minutes and dies again.
    I've replaced the crank sensor, coils, ignition control module, etc.. It had an aftermarket alarm, it has been totally removed. What else can I go looking at? I've emailed ZZP, maybe I can sort something with testing the PCM.
    B.
  2. #2 Re: No spark
    May 2008
    Schuyler, NE
    The only thing you need for spark is the crank sensor, wiring harness, icm, coils, wires, and plugs. Basic ignition is very simple on these cars. If you have no spark, something is wrong with one of those.
  3. #3 Re: No spark
    St. Louis
    Try swapping the stock ECM back in and see if it stays running.
  1. 98 Gtp No Spark
    By GreenGTP91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2013, 10:35 AM
  2. 3.1 and no spark
    By TAYLORPCC in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2010, 01:45 AM
  3. No spark HELP!!!
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:30 PM
  4. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  5. Spark
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:06 PM
