Thread: P0300 Code help needed
Results 1 to 3 of 3
  1. #1 P0300 Code help needed
    Oct 2018
    Bay Area CA
    I am trying to fix my friends mothers 08 GP with the series 3 3.8L. Getting a P0300 General misfire code. Checked plugs and wires, even to the point of disconnecting plug wires one at a time and the engine runs the same. Definitely missing at idle, smooths out at higher revs, definitely down on power and mileage, I believe it is running in "safe mode". Replaced all 6 injectors, since that seems to be a pretty common problem, I also read a TSB for that model year about a problem with the injectors getting plugged up. Car does run a bit smoother but still missing. Any help would be greatly appreciated. Thanks in advance!!
  2. #2 Re: P0300 Code help needed
    Get a live data scan tool on it. See exactly what cylinders are misfiring and fix the issue from there.
    Could be the spark plugs, could be a dying coil pack or the ignition control module under the coils.
  3. #3 Re: P0300 Code help needed
    high miles? clogged cat is possible.
  1. Need help with a P0300 code
    By derpyimp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2018, 03:18 PM
  2. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  3. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  4. most common p0300 code fix
    By Wingsfreak9 in forum General Tech Discussion
    Last Post: 09-21-2011, 01:12 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
