Thread: Replacement headlight housings - do they suck?
Results 1 to 8 of 8
  1. #1 Replacement headlight housings - do they suck?
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    My headlight housings are super fogged and one is also cracked. They are too far gone to be restored, so I'm looking for replacement housings. Has anybody tried the housings available on ebay/amazon and can tell me how they compare to OE housings? Just want to make sure I get a product that will work well enough to be worth spending the money. I really like the retrofitted housings, but I can't justify spending $400 on them and so I need cheaper alternatives.
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #2 Re: Replacement headlight housings - do they suck?
    Antioch, IL
    04+ its retro or bust the 97-03 ebay h eadlights worked just fine for those years. everything newer sucks
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Replacement headlight housings - do they suck?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ItHurtz View Post
    retro or bust
    This.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Replacement headlight housings - do they suck?
    Or to answer his question, new stock housing from a decent vendor work just fine if you just need new headlights.
    I've run like 4 different sets of new stock housings from the brand TYC without issue. After like 4-5 years they start the yellow again but by then the car is likely not be yours anymore.
  5. #5 Re: Replacement headlight housings - do they suck?
    Nov 2017
    Utah
    Thank you, fivefingerdeathpunch. Just the input I needed. Maybe you or someone else would know this too: is it worth it to put some LEDs in the fog lights on the 04+ cars for increased output at night?
  6. #6 Re: Replacement headlight housings - do they suck?
    That I don't know.
    Depending on how the light is distributed across the ground it might just scatter even worse and cause the light to shine into other peoples eyes as they drive towards you.
    In lights that have a cut off for the lenses that help point it downward and stop the scatter effect it would surely help a lot.
  7. #7 Re: Replacement headlight housings - do they suck?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I bought Ebay headlights 2 years ago for my 04. Still look brand new. No fogging. I recommend. As for the fog lights there is no light distribution pattern. It would just be annoying glare to every oncoming driver. Please don't do it. There is no cut-off or good beam pattern. It is mostly for looks not for good lighting. You would be much better off to buy a set of Ebay headlights and retrofit LED or HID projectors into the housing if you want better lighting. You would get better light pattern without blinding everyone else on the road. (You know... people who throw LEDs or HID bulbs in a halogen housing with huge glare blinding every oncoming driver.)
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  8. #8 Re: Replacement headlight housings - do they suck?
    Nov 2017
    Utah
    Yeah, I know not to put HIDs in stock housings. The fog lights aim low have a pretty sharp cutoff though, so that's why I was wondering if they would take LEDs without blinding everyone else.
    Anyone have some experience with how much they spent to retrofit their own low beams?
  1. 97-03 headlight housings.
    By Rlugo87 in forum For Sale - Parts
    Last Post: 06-06-2017, 01:51 AM
  2. condesation in new headlight housings
    By 2004GrandPrixGT1 in forum Visual/Body Modifications
    Last Post: 11-26-2012, 01:31 PM
