Thread: EGR Delete
Results 1 to 20 of 25
  1. #1 EGR Delete
    Jan 2018
    US
    Is there any benefits to deleting the EGR? Pro's and Con's etc anyone?
    I been trying to research and came across a couple of threads saying there's an EGR Delete Kit? Was wondering where.
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: EGR Delete
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Pro: slightly cleaner intake, easier tuning, less engine bay clutter, less leak points
    Con: Slightly less mpg (like 1 mpg), can increase kr very slightly
    Don't waste money on the kit. Take off egr system, cut the egr pipes, take the brackets left over, take a penny and take some high temp copper rtv and use it to secure and seal the penny. Then re-install flanges and let dry. That's my 2 cents!
  3. Thanks showtastiik thanked for this post
    Likes showtastiik liked this post
  4. #3 Re: EGR Delete
    you need it removed in your tune, so not tuned, leave it alone. other wise the pcm thinks its working when its not and you could do some damage.
  5. Thanks showtastiik thanked for this post
  6. #4 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Thanks Scotty, forgot to mention that. He's right because the egr is a metered vacuum leak, plus the exhaust gases affect the combustion process. Once tuned, delete as above. Good news is even canned tunes work for this.
  7. Thanks showtastiik thanked for this post
  8. #5 Re: EGR Delete
    Jan 2018
    US
    Thanks! Yeah, that last part from Scotty was good to know because I was going to get on that today... So if I'm understanding correctly, No EGR delete until I get a tune?
    Where's the best site to get a canned tune? ZZP?
    Also when it's time to block off EGR. Which section will be blocked off and left alone or even open? 1, 2 or 3 (Refer to image below)
  9. #6 Re: EGR Delete
    you block off 2 and 1 take the rest off and toss it in the trash can lol
    i made my own block off's. 1 inch flat stock, drill a hole for the bolt, then cut it to length so it covers the hole rtv around the hole and bolt it down. free block off's.
  10. Thanks showtastiik thanked for this post
  11. #7 Re: EGR Delete
    The Boss Iceman6669's Avatar
    Jun 2011
    I personally ran for years with the EGR deleted before I tuned it out. And I actually saw a small increase in mpg.
    2011 F-150 Yote powered
  12. Likes showtastiik liked this post
  13. #8 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Cut pipes on lines 1 and 2. Remove pipe, remove rest of egr. Place pennies and rtv. Install and let cure. Done.
  14. Thanks showtastiik thanked for this post
  15. #9 Re: EGR Delete
    Jan 2018
    US
    Quote Originally Posted by Iceman6669 View Post
    Wow really? MPG increase, I wonder why. Looks like it'll be safe to delete EGR before tune
  16. #10 Re: EGR Delete
    Jan 2018
    US
    Lol gotcha
  17. #11 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Here's what it should look like in both sides to give you a better picture:
    Sorry for the egr plug hanging down and you won't have some of that tubing (or headers) there so it might look a bit different.
  18. Thanks showtastiik thanked for this post
  19. #12 Re: EGR Delete
    Jan 2018
    US
    Ooh, ok! Even better! 2 Penny's haha. I like that. Thanks for that visual. Made it a lot easier for me.
  20. #13 Re: EGR Delete
    ill let ya in on a secret, lol not really, but you just dont know yet, egr tube on the exhaust manifold, its bolt head is on the back side, threads into the egr tab. its fun to get off.....
  21. Likes showtastiik liked this post
  22. #14 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Haha true that. Mine was rusted really bad. You'll definitely want some pb blaster and a 6 point wrench and some curse words. Much easier with headers.
  23. Likes showtastiik liked this post
  24. #15 Re: EGR Delete
    yeah cause headers you put that damn thing on before you install em lol
    i used a 1/4 ratchet smaller is better here.
  25. #16 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Quote Originally Posted by showtastiik View Post
    Yeah np! I had a hard time visualizing it too. Just sits in the flange. You'll see it when you remove the egr. Good luck!
  26. Thanks showtastiik thanked for this post
  27. #17 Re: EGR Delete
    Aug 2017
    Raytown, MO
    You're lucky! Took me 2 foot 3/8" breaker bar heated with propane soaked with pb blaster and hit with 5lb hammer! Thing was STUCK!
  28. #18 Re: EGR Delete
    wow, i did break mine free with a 3/8 th but theres no room to work it, so i went smaller. used a deep socket too, got you off the manifold just enough.
  29. #19 Re: EGR Delete
    Aug 2017
    Raytown, MO
    Lol yeah, I had the luxury because I took off the header with the egr attached, and had it out of the car when I did my header install.
  30. #20 Re: EGR Delete
    Jan 2018
    US
    Haha Yeah! I was like, why would they! I took it off and tried threading it in the way it made sense. I had that feeling as if my best friend gave me a cheat code that I will never die but it didn't work haa.
  1. delete egr?
    By 93TAJC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2010, 12:17 PM
  2. delete this
    By EJRJR91 in forum Visual/Body Modifications
    Last Post: 10-25-2010, 09:36 PM
  3. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  4. delete please
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 12:57 AM
