Thread: Anyone have a 08 grand prix ABS pinout and wiring diagram
Results 1 to 4 of 4
  1. #1 Anyone have a 08 grand prix ABS pinout and wiring diagram
    Feb 2017
    MI
    I have an o8 Grand Prix base model and my scanner can't link to the ABS module. Says to check power and ground. It has power and Gnd at the wiring harness. I tried a different ABS module but get the same results. Anyone have the pinout and wiring diagram for the ABS system ?
  2. #2 Re: Anyone have a 08 grand prix ABS pinout and wiring diagram
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    You need a TechII or Snap-On ABS reader to see ABS codes on these cars. I had to bring mine in. Cost = $30
    Does it do this? I have a bad ABS module. http://vid1184.photobucket.com/album...811_174809.mp4
  3. #3 Re: Anyone have a 08 grand prix ABS pinout and wiring diagram
    GTP Level Member
    Oct 2014
    Somehow abs was an option and mine does not have it. So no help here.
  4. #4 Re: Anyone have a 08 grand prix ABS pinout and wiring diagram
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    I have the 98-03 diagram, not sure if it's the same. It's possible that the ABS stayed the same across the model break in 2004.
    Link to thread
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  1. 2001 grand prix brake wiring diagram needed.
    By paedbo in forum General Tech Discussion
    Last Post: 11-21-2015, 08:20 PM
  2. 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    By Xanthous in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2015, 08:21 AM
  3. DIC wiring pinout
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 05-12-2013, 06:15 PM
  4. Replies: 0
    Last Post: 07-19-2012, 07:16 PM
  5. Fuel pump wiring diagram for 1996 Grand Prix LE with a 3.4L
    By 96LimitedEdition in forum General Tech Discussion
    Last Post: 07-23-2009, 01:03 PM
