Thread: Fuel line leak
Results 1 to 9 of 9
  1. #1 Fuel line leak
    Jul 2016
    Texas
    I have a 2004 Pontiac Grand Prix and recently smelled fuel when driving and stopped at a red light. Upon further investigation I found a leak in the metal fuel supply line where it curves up into the engine compartment about an inch below where the metal connects to the black plastic line. Is there any way to safely repair this? I have called the dealership and the part is discontinued. The part number is 10339938. If I can find an aftermarket part I do t mind replacing the metal portion of the fuel line I'm just not sure how to disconnect it from the black plastic portion.
  2. #2 Re: Fuel line leak
    cut, chop, rebuild that line.
    if theres enough tube before the plastic line you can either use a double flair tool and a union to replace the bad line, or compression fittings.
    there is a place on line that sells all new fuel lines. another member just got them for a 97-03 car. gas tank to engine.
  3. #3 Re: Fuel line leak
    Jul 2016
    Texas
    Ok since I know there's a place to get an aftermarket line I'd rather go that route. So now I'm just wondering how this metal line disconnects from the plastic... Just pull? I don't wanna cause any further issues. I know there's a quick connect a little further down the line but surely there's a way to disconnect at the plastic to metal joint.
  4. #4 Re: Fuel line leak
    dont think it comes apart, new line come with the new plastic line.
  5. #5 Re: Fuel line leak
    Jul 2016
    Texas
    Ok that works for me, thanks for the help! Now that I'm under the vehicle looking at it I'm wondering how easy it will be to run a new line through this tight space with all the curves it has in it.
  6. #6 Re: Fuel line leak
    http://www.grandprixforums.net/threa...tion-NO/page28 theres pics of his lines. he may say where he got them a page back.
  7. #7 Re: Fuel line leak
    Jul 2016
    Texas
    Ok so update I was able to obtain a new (used) line from the salvage yard. I pulled the old one out but the new one isn't going in very easily too many twists and turns I've been trying to get it in for about an hour now with no luck. Does anyone have any tricks to get this in here. I could really use the help.
  8. #8 Re: Fuel line leak
    lowering the sub frame 2 inches might help, i know that cluster of brake and fuel lines pass right by the sway bar bushing mount body and frame.
  9. #9 Re: Fuel line leak
    Jul 2016
    Texas
    Well good news is I got it on. Bad news is I linked the **** out of the black portion of the line doing so. Guess I'll cross my fingers and hope enough fuel can pass through the line to make the care driveable
  1. Fuel Rail Line Connector Leak
    By thekidinbuff in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2015, 06:47 PM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
  3. fuel line leak on top of s/c
    By Scottydoggs in forum General Tech Discussion
    Last Post: 01-27-2012, 03:50 PM
  4. fuel line leak
    By anlo in forum General Tech Discussion
    Last Post: 12-19-2010, 09:39 PM
  5. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
