Thread: roll cage/ gutted interior
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 106
  1. #1 roll cage/ gutted interior
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Just curious who has one and what their setup looks like also wondering how light you can get a grand prix I wouldn't think you could take more than 100lbs out
  2. #2 Re: roll cage/ gutted interior
    May 2008
    Winnipeg, MB
    if you take out all of the interior pieces you should save a few hundred pounds, no dash, passenger seat, rear seat, door moldings, roof liner, floor carpet, speakers, spare tire, race steering wheel and drivers seat
    how extreme do you want to go?
    2007 Pontiac Grand Prix
  3. #3 Re: roll cage/ gutted interior
    putting a cage in the car is doing the opposite of losing weight, so you're kind of going to run into issues there.
    i, however, do plan to do a half cage in my car. just wrap a bar around the back of the front seats and connect it to the b-pillar and the floor below it. after that i was going to put a nice x-brace in the trunk to connect the rear shock towers. then if i felt like getting even more frisky i would make a front strut bar that also connects to the firewall to form a triangle. going even further you connect the upper portions of the frame rails on the front of the car to the middle of the lower cross beam. there are tons of ways to stiffen the chassis without adding a full cage that in most cases will be completely useless.
    however, as far as gutting the interior, you could lose a couple hundred pounds. the seats are fairly heavy. removing portions of the dash may help out your goal too.
  4. #4 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    Well if I do it I figure its a all or nothing thing and I don't wana do it unless it makes a noticeable difference
  5. #5 Re: roll cage/ gutted interior
    May 2008
    Winnipeg, MB
    I can think of a few more things that are kinda extreme
    delete the battery and boost the car every time you need to start it, will run with just the alternator
    a/c delete, you won't need to be kept cool for a 1/4 mile run
    no rear brakes, 16" black steel rims
  6. #6 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    I want it to still be able to drive on the street I already plan on the ac and hvac but I thought about plexi glass Windows in the back and wind shield I still want the front Windows to go up in down id like to keep two seats cause what's the point if I can't show the car off
  7. #7 Re: roll cage/ gutted interior
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    I have gutted my interior some what and have gotten the car down to around 3000. I took out the rear seats, all the rear speakers, BUT put the rear cover back in place since it only weighs about a pound or so. Passanger seat is removed, AC delet, with everything that goes with it. Cruise control is gone. Alum sub frame up front. Rear Steel bumper support is removed, the front support has a pretty big peice cut off of it for my Frozen boost FMHE. Everything in the truck in gone that I could pull out as well.
    I still have all my panels in the car, since they do not weigh a whole lot, plus it makes the car look nicer with them in place. I still have speakers in the door, so I can listen to tunes when I do drive it on the street. I have a full dash still as well. I think that is all that I can remember off the top of my head.
    The only problem is, is I hope with my new build that I will dip into the low 11's, but that means I will have to put a cage in, and I will be back to where I was, with the added weight. But that is ONLY if I can get there..........
  8. #8 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    how do you get rid of the subframe isn't that needed?
  9. #9 Re: roll cage/ gutted interior
    Charles City, IA
    He said he swapped his steel one for the newer aluminum one.
    SMGPFC Two Nipple General
  10. #10 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    oh gotcha thats not a bad idea
    You can get rid of the subframe if you make a nice tubular one to go in its place. That would shed a ton of weight and be awesome.
  12. #12 Re: roll cage/ gutted interior
    Oct 2008
    Cincy
    Quote Originally Posted by Taz Magister View Post
    Quote Originally Posted by TheOtherNick View Post
    Thank you for clearing that up................For a second I thought I missed typed.
    Now that would be killer. I would think you could do it, but there is alot going on up front and a TON of torque being pulled on it, if you are racing. I think the best for now is the Alum. Subframe. I guess you could "swiss cheese" the sub frame to free up more weight. I don't recommend it, but..................
  14. #14 Re: roll cage/ gutted interior
    Jan 1970
    Maquoketa, Iowa
    This has most of this stuff already covered...
    ClubGP Message Forum troubleshooting
  15. #15 Re: roll cage/ gutted interior
    Waukesha, WI
    cut the trunk floor+ spare out and mount an aluminum plate for a floor section, drop the gas tank and install a 10 or so gallon fuel cell with a decent external flow pump would help with weigh, speed holes in everything
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  16. #16 Re: roll cage/ gutted interior
    Dec 2010
    Ohio
    Let's say I could get it around 3000lbs what type of difference would that be in the quarter
  17. #17 Re: roll cage/ gutted interior
    Waukesha, WI
    every 100lbs is 1\10th of a secondish
    RayRay
    92 Turbo miata
    02 lexus is300
  18. #18 Re: roll cage/ gutted interior
    Kansas
    Cole going to ultra racecar status?
  19. #19 Re: roll cage/ gutted interior
    Omaha, NE
    Race Battery would help with the streetable thing...
  20. #20 Re: roll cage/ gutted interior
    Waukesha, WI
    cole a main hoop with 2 down bars would be bare mininum for tech at the track? i think go 8 point like a boss
    RayRay
    92 Turbo miata
    02 lexus is300
  1. Windows roll down fine but roll up SLLLOOOOWWLLYYY
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2013, 07:21 PM
  2. My new beard cage.
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 10-11-2011, 06:49 AM
  3. Gutted Turbo Hatchback Civic=RAPING
    By chevyy1212 in forum Track Sessions and Kills
    Last Post: 06-08-2011, 10:19 PM
  4. 1/4 Mile: Helmet? Roll Cage?
    By GrandPrixGTP1 in forum Off Topic Discussion
    Last Post: 01-10-2011, 12:42 PM
  5. Gutted Airbox pictures
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 05:44 AM
