Thread: Daytona v/s Regular GTP spoiler
Results 1 to 5 of 5
  1. #1 Daytona v/s Regular GTP spoiler
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    I've run across a daytona spoiler that is already the correct color for my car for a pretty good price, but I've already got the regular GTP wing. Anybody know if the Daytona would use the same mounting holes, or at least cover them up to prevent leaking? At a glance, I'm thinking not.
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  2. #2 Re: Daytona v/s Regular GTP spoiler
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Holes don't line up for Daytona/40th style spoilers, only the Limited Edition big wings did. The similar-designed SLP Gen II was made to use the normal holes, as were the other aftermarket options (SD, MPD F.1, etc.), since they had to work with our original mounting locations.
    Also, swapping to these shorter spoilers without swapping the truck lid exposes new sections of paint that may need TLC.
  3. #3 Re: Daytona v/s Regular GTP spoiler
    Apr 2020
    Upstate SC
    Quote Originally Posted by dezldave961 View Post
    Good info, thanks. out of all of those, the only options I see anywhere new are SLP knock- offs, and it looks like there are 2 options on those, being the "whale tail" and the low- pro. Assuming the knock- offs are made from the same molds, etc., would either one use the same holes?
    99 GTP:
  4. #4 Re: Daytona v/s Regular GTP spoiler
    Banned
    May 2008
    Quote Originally Posted by ThatOldCarSmell View Post
    Not really "knock-offs"... the SD (very similar to SLP Gen I) and MPD F.1 style (huge one) have been around for almost 20yrs, and are probably leftover inventory from the peak of this market 10+yrs ago. As mentioned, SLP/SD/MPD/etc. use regular GP spoiler mounts, since they had to be able to bolt-on, not coming from the OEM as a different feature.
  5. #5 Re: Daytona v/s Regular GTP spoiler
    St. Louis
    I have a true SLP Gen I spoiler on my 00 GT and all I had to do was elongate a few of the stock bolt holes and it bolted down with no issues. I didn't have any new paint exposed since it follows the OEM edge.
    I would recommend installing a thin nylon spacer between the spoiler and the trunk then sealing the bolt holes top and bottom with silicone that way the spoiler is raised up off the trunk ever so slightly (if done right no one will notice the slight gap) and allows water and debris to pass underneath and not sit under the spoiler causing rust.
    If you want to go with the Daytona spoiler then your best bet would be to find an SE model with no spoiler and then have the Daytona spoiler installed.
  6. Likes ThatOldCarSmell liked this post
  1. Replies: 11
    Last Post: 10-20-2018, 01:25 AM
  2. Special Edition Spoiler fitting on regular trunk?
    By Curt7 in forum Visual/Body Modifications
    Last Post: 06-24-2012, 02:18 PM
