Thread: Putting HUD from a GTP into an 04 GT.
Results 1 to 12 of 12
  1. #1 Putting HUD from a GTP into an 04 GT.
    SE Level Member ULTRA MUFFINS's Avatar
    Nov 2016
    Michigan
    Chats
    Hey, I came across a full HUD setup with wiring harness included and I was wondering what I would need to splice if anything, to get it to function properly. Also if I could just swap the whole top part of the dash into my car.
    Any help would be greatly appreciated.
  2. #2 Re: Putting HUD from a GTP into an 04 GT.
    Nov 2012
    Madison
    Chats
    I take it 04+ GTP, well anyway.
    You probably already searched for this..............http://www.grandprixforums.net/threa...04-HUD-Install
  3. #3 Re: Putting HUD from a GTP into an 04 GT.
    Nov 2016
    Michigan
    Chats
    Quote Originally Posted by spazzz View Post
    Yup, already went through that just was confused on some of the cutting and wiring, just assume it'll plug into a connector in the car. The cutting is the only really confusing part to me.
  4. #4 Re: Putting HUD from a GTP into an 04 GT.
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chats
    1417
    It looks like you have to cut the dash pad to me. I don't think you can swap just the pad part, but I could be wrong on that.
    This is from near the top, and it is kinda vague.
    ~ "utility knife or razor blade (for precision while cutting the dash padding)"
    ~ "Dremel or some sort of rotary too with a QUALITY cutting wheel (to cut through the hard plastic dash under the dash padding)"
  5. #5 Re: Putting HUD from a GTP into an 04 GT.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    Man I am going to miss my HUD. My 04 has it but the 07 does not. It looks like too much of a hassle to do. I'm not very good at wiring.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  6. #6 Re: Putting HUD from a GTP into an 04 GT.
    Dec 2012
    troll land
    Chats
    A lot of it is just matching colors. After HUD swapping a 97 Monte(a car that NEVER had HUD) I wouldn't hesitate to HUD swap another car.....in fact I'm considering HUD swapping my brothers 88 iroc
  7. #7 Re: Putting HUD from a GTP into an 04 GT.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    Ill take out the HUD from my 04 and keep it just in case I feel spunky one day. Ill have to search more for a pic tutorial.
  8. #8 Re: Putting HUD from a GTP into an 04 GT.
    Nov 2016
    Michigan
    Chats
    If you need help with wiring and cutting let me know I just recently finished my swap
  9. #9 Re: Putting HUD from a GTP into an 04 GT.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    Thanks. once I get done making 2 cars into one I may tackle this. I am so used to the HUD. My last 3 grand prix had it. I get in my wife's van and I'm lost!!
  10. #10 Re: Putting HUD from a GTP into an 04 GT.
    Mar 2019
    Colorado
    Chats
    If you ever grow the courage to cut a hole in your dash, believe it or not, the wiring connection is actually taped down directly behind the instrument panel in the HUD cavity. I installed the HUD in my 05 GTP, and cutting the dash was the only hard part! The only other section you have to add is in the center console for the control dial. The harness is modular in that area, so installing one is simple as well, just replace the entire section running to the back-seat 12v. Hope this helps!
  11. #11 Re: Putting HUD from a GTP into an 04 GT.
    Dec 2018
    MI
    Chats
    looking for any help on what you did to make sure when cutting the dash pad when upgrading a hud in a 05. I have all the parts, hud, center console, dash piece.
  12. #12 Re: Putting HUD from a GTP into an 04 GT.
    Nov 2016
    Michigan
    Chats
    For my GP it needed to be wired up manually since there was no existing plug behind the dash where it goes. I just did this by matching the wires on the center console to the plug for the HUD itself and made my own harness. For cutting the dash pad, all I did was use a dremel after making a template using the windshield cowl piece. As long as you make the cuts under the dash piece you can cover it up with the cutout.
  1. putting 22s on 04 gt2
    By 504Quan in forum Visual/Body Modifications
    Last Post: 01-31-2015, 12:00 AM
  2. putting an L67 into a '99 GT few questions
    By ColeTrain84 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2013, 04:52 PM
  3. Thinking of putting a 3.8 SC in my 99 s10
    By rc10gt7090 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2012, 12:11 PM
  4. Can't get key out after putting car in park.
    By Dusty02se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2010, 02:44 PM
  5. Putting Motor In
    By dcbur2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2009, 10:44 AM
