Thread: 2000 gp turbo new pcm location?
Results 1 to 8 of 8
  1. #1 2000 gp turbo new pcm location?
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    Were is the best place to mount the pcm? I cant find good info and i was hoping someone had advice? Thank guys
  2. #2 Re: 2000 gp turbo new pcm location?
    Omaha, NE
    You could splice in some longer wires (solder them so they are done right). Then mount it wherever you wanted.
  3. #3 Re: 2000 gp turbo new pcm location?
    Feb 2013
    Missoula, MT
    Thats probaly what im going to do. I guess i was hoping that zzp or milzy's kits came with some trick instructions?
  4. #4 Re: 2000 gp turbo new pcm location?
    Jan 1970
    Maquoketa, Iowa
    Usually just mount them in the stock location or ziptie them there.
  5. #5 Re: 2000 gp turbo new pcm location?
    Omaha, NE
    Wbody store sells PCM trays too, but it would probably be better to get it away from the high temps of the turbo.
    You could try a turbo blanket.
  6. #6 Re: 2000 gp turbo new pcm location?
    May 2013
    illinois
    double sided tape to the inner fender, but if you want it to look trick i moved my pcm and fuse block to the glove box it cleans up the engine bay nice but is alot of work
  7. #7 Re: 2000 gp turbo new pcm location?
    Feb 2013
    Missoula, MT
    The pcm tray is a little bulky for my setup, its a great solution tho. Before this i just stuck the pcm to the flatspot with some spray foam insulation. Im going to use a combination of what you guys said and extend the wires mounting the pcm verticaly on the inner frame/ fender. Itll involve moving some air con pipe over, then maybe a sheet metal heat shield, heat wrap, and a couple screws. Thanks guys!
  8. #8 Re: 2000 gp turbo new pcm location?
    Texas
    I was unable to use the stock location due to the Turbo when mounted literally sat on top of the wires. I placed the PCM between the front bumper and fender. There are pics in my build thread.
    85 Corvette
    01 TA
    03 Z06
  1. 2000 Grand Prix GTP Turbo
    By TheGerm in forum Members Rides
    Last Post: 08-14-2014, 07:34 AM
  2. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
  3. Front Crash/Impact sensor LOCATION on 2000 GrandPrix Gt 3.8
    By mpls612 in forum General Tech Discussion
    Last Post: 06-26-2013, 11:34 PM
  4. WTT/WTS 2000 GTP Turbo 450=hp, streetable
    By big_boy63 in forum For Sale - Vehicles
    Last Post: 06-29-2012, 11:19 PM
  5. IAT sensor location turbo?
    By UR LOSN in forum Turbo
    Last Post: 02-20-2009, 12:38 PM
