Thread: planning a turbo build
Results 1 to 11 of 11
  1. #1 planning a turbo build
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok guys i am planning on getting another gp and just wanted to know what i need for a turbo build on a l36
    crossover with flang
    turbo
    bov
    waste gate
    charge pipe
    3"dp 42.5 injectors
    tuned pcm
    l67 map
    oil feed line and return
    misc fittings for tapping the oil pan
    am i missing anything im just wanting to get a list so i can compare how much a turbo l36 build would be compared to a s/c l67 build also what about twin charging ive heard its not very reliable can anyone shead some light on that please thanks
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: planning a turbo build
    Texas
    If you go with a 3" upper dp(off turbo) you will need to pick up a Monte Brake Booster.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: planning a turbo build
    Dec 2010
    Noble, Oklahoma
    FMIC , and some vacuum line . lol
    Boostin To A City Near You
  4. #4 Re: planning a turbo build
    Charles City, IA
    If you are not running an intercooler pick up a meth kit.
    SMGPFC Two Nipple General
  5. #5 Re: planning a turbo build
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    skip 42's and get 60's. add a lq4 maf aswell
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: planning a turbo build
    Donating Users Tengis's Avatar
    Houston
    Skip the LQ4 and add a modified 99+ MAF in a ported 97 throttle body.
    Meth = lame.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  7. #7 Re: planning a turbo build
    thanks for the input so if i go lq4 maf ill need n* tb what year tb am i looking for or are the all the same and i would do fmic over meth also is there away to get around changing the brake boost this turbo buil will be either a impala or a grand prix more likely an impala as they are cheaper to pick up
    sold 97 GTP stock
  8. #8 Re: planning a turbo build
    Houston
    Sigh.
    Satin Purple 97 GTP
  9. #9 Re: planning a turbo build
    Quote Originally Posted by Tengis View Post
    Sigh.
    why sigh
    sold 97 GTP stock
  10. #10 Re: planning a turbo build
    Quote Originally Posted by nascartech View Post
    why sigh
    because youre asking questions you shouldnt have to ask if youre going turbo. you need to do a lot more researching before you commit to this or you're going to find yourself in a world of hurt very quickly.
  11. #11 Re: planning a turbo build
    SE Level Member Sinister Drag Designs's Avatar
    if the build is on an impala you wont need another brake booster as they come with the upgraded smaller booster from the factory.
    You dont need an aftermarket throttle body with a turbo setup unless your looking for slightly better driveability off boost(which wont mean much on a properly sized turbocharger for your application).
    Use a 99+ modified as mentioned or at least use a LT1 maf sensor. Most people are able to get into the mid teens boost wise before outflowing the LT1 unit. You will need to scan to find out when to upgrade.
    If your looking for project 00-05 impala, I might know where to find a lightweight LS with a roll cage, momo race seats, and a rear line lock.
    Shoot me an email if interested
    Robert@SinisterDD.com
  1. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  2. Twin charge, Turbo, or build up the Super charger?
    By AdamBall in forum Off Topic Discussion
    Last Post: 04-29-2010, 12:19 AM
  3. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
  4. What LIM can I run if planning a Gen V swap later on?
    By Black18Ice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 07:29 PM
  5. Turbo build advice: GTP and GS mating..
    By LowlyfeGTP in forum Turbo
    Last Post: 05-27-2008, 11:29 AM
