Thread: Turbo planning and questions
Results 41 to 60 of 64
  1. #41 Re: Turbo planning and questions
  2. #42 Re: Turbo planning and questions
    Antioch, IL
    You would be almost done without that fbody junk!
    2009 Challenger SRT8
    Expert at being gay.
  3. #43 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Feeling like that is true, but gotta press on. I turboed my 95 Beretta and it was wayyy more complicated than this.
    I'm going to try and do the other side tomorrow and order the block off plate from zzp. Wire it up and hopefully be ready for my birthday in March
  4. #44 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Still working. Getting closer and looking more like a car again
    https://i737.photobucket.com/albums/...303_181523.jpg
    Going to run the boost controller inside the cabin, just sat it there for now
    https://i737.photobucket.com/albums/...303_181518.jpg
    Had to cut the fog lights out for piping. Probably didn't have to, but it worked
    https://i737.photobucket.com/albums/...303_181459.jpg
    Fuel rails and the 42's in. Next finish the vacuum and wire up the TB
    https://i737.photobucket.com/albums/...303_181453.jpg
  5. #45 Re: Turbo planning and questions
    Antioch, IL
    get 60's those 42's wont let you do much of anything once the boost kicks in good
  6. #46 Re: Turbo planning and questions
    Apr 2015
    Columbus, OH
    Might want a 45° on the compressor outlet. Looking good though ��
    Top Swapped 01 Imp
  7. #47 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Yea, I'm struggling with the driver side piping. That corner just
    wont lock into place. Everything else is looking good. Rear
    mani blockoff be here next week from zzp. Should be ready
    to attempt firing it up by Friday..fingers crossed
  8. #48 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Ok, ran into a problem.. With the f-body intake and camaro alternator the standard(l36)
    serpentine belt doesn't fit. Does not fit over the alternator. Also went and picked up a
    belt from a L36 Camaro and is too loose. Any thoughts as to what i can go with? I'm
    pretty close, just this, oil return, and rear mani block off and I can actually start it.
  9. #49 Re: Turbo planning and questions
    have you tried switching the smooth idler pulleys around?
  10. #50 Re: Turbo planning and questions
    ^between the 3" and 3.5" oversized one
  11. #51 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Not familiar.. Please explain
  12. #52 Re: Turbo planning and questions
    actually that method is used on the s/c belt when swapping to smaller pulleys.
  13. #53 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Damnit, I wish bout to hit the yard.. Kinda stuck on this one
  14. #54 Re: Turbo planning and questions
    Antioch, IL
    Just measure it. If its to loose by how much? Take 6" off and try again. I moved the alt to the ac compressor side, deleted alt bracket and mounted a custom pulley by the dogbone. Walked into advance auto asking for sizes, took 2 tries but I had success.
  15. #55 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    After doing some reading, I stumbled on the thread about the CS144 alternator.
    I don't have one, but they had used the Camaro bracket. Think i'm going to try
    the one they used this morning. Soon as the rain stops
  16. #56 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Yea, its a cluster***k under there, but i got some progress
    Grand Prix first turbo start - YouTube
  17. #57 Re: Turbo planning and questions
    not bad. mine was way worse so don't get too wrapped up on how ugly the layout is. if it works, it works!
  18. #58 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    Yea thanks, long time coming. Now just addressing issues and doing
    some clean-up. Leak at the rails, so if the yard is open i'll replace
    this afternoon
  19. #59 Re: Turbo planning and questions
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Any progress with this build?
    Sent from my SM-G973U using Tapatalk
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  20. #60 Re: Turbo planning and questions
    Dec 2016
    Baltimore
    It's done, now i'm running into issues with dumpin too much fuel.
    Just buttoning up things as i go along. Got more vids coming
  21. Likes bandook, dazedandconfused liked this post
  1. Replies: 8
    Last Post: 08-21-2015, 05:58 PM
  2. z3 turbo kit questions
    By Nchristopherson in forum Turbo
    Last Post: 03-16-2015, 11:02 AM
  3. Planning on getting these lights, questions.
    By FriboRage in forum General Tech Discussion
    Last Post: 01-19-2014, 01:20 AM
  4. planning a turbo build
    By nascartech in forum Turbo
    Last Post: 02-10-2011, 06:59 PM
  5. Turbo Questions
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 02:26 PM
