Thread: PCV system and going turbo
Results 1 to 7 of 7
  1. #1 PCV system and going turbo
    Nov 2015
    Monroeville, Pa
    Chats
    Hey guys what are you doing with the PCV system when you add a turbo? Cant find alot of info on eliminating it or re-working it. Thanks
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #2 PCV system and going turbo
    Quincy, Mass
    Chats
    1847
    Run a breather, pvc hole in the throttle body gets tapped and plugged. And then run a catch can.
    Some run a hob, I think that's the word, switch to keep air moving at idle.
    No more GP 04 Impala SS Indy:
  3. #3 Re: PCV system and going turbo
    May 2008
    Schuyler, NE
    Chats
    265
    Some run a vacuum pump on a Hobbs switch to keep the crankcase under vacuum all the time.
  4. #4 Re: PCV system and going turbo
    Nov 2015
    Monroeville, Pa
    Chats
    Why couldn't you just put a one way check valve to the throttle body so when under vac it works normally then under boost it blocks flow into crankcase?
  5. #5 Re: PCV system and going turbo
    May 2008
    Schuyler, NE
    Chats
    265
    You can do that as long as you are sure the check valve seals.
  6. #6 Re: PCV system and going turbo
    May 2008
    Schuyler, NE
    Chats
    265
    But you still need to vent the crankcase under boost, or it will find its own vent.
  7. #7 Re: PCV system and going turbo
    hangover park IL
    Chats
    910
    Its not that its going to find a vent it's that you will dramatically increase oil blow by and likelihood of detonation from oil getting in the combustion
    ~James~ Psychotic Gearhead
  1. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  2. 2004 Grand Prix GT. Service ABS System, and Taction Control System
    By Erika Schultz in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2012, 05:26 PM
  3. Turbo's System (56k warn)
    By 1LoudGrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 07-05-2009, 02:14 AM
