Thread: Just got a turbo kit, couple quick questions
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 101
  1. #41 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Quote Originally Posted by GTPChristopher View Post
    I like Scotty's idea better. Why not save a few bucks when possible?
    Me too, but don't we still need an adapter plate for the N* TB? Or does the north star bolt up to the L26 UIM?
  2. #42 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Just out of curiosity, how much boost are you planning on running? The tranny is the weak link when going turbo and running high boost.
    Once I get everything running, I'll probably have triple edge build up my trans.
  3. #43 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Quote Originally Posted by SgtMarshal View Post
    some people have had bad luck with the LQ4 maf sensor and turbocharged applications. you could use an LT1 style maf, but it's old technology. the LS7 maf is a card style and would work better. another option is the mini afc, that zzp sells.
    What's the difference in mafs between the lt1 and ls7? I'm assuming I'm going to need the housing from whichever one I get.
  4. #44 Re: Just got a turbo kit, couple quick questions
    http://www.grandprixforums.net/threa...urbo-gp/page22 this is why. and this guys running big boost #'s
  5. #45 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Yikes. Ok, will not go that route then.
  6. #46 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    BrandonHall10 built my tranny. He does phenomenal work, maybe shoot him a msg when you're ready and he could shoot you a quote.
    Sent from my LGLS675 using Tapatalk
  7. #47 Re: Just got a turbo kit, couple quick questions
    GTP Level Member
    Jan 2015
    Lincoln, NE
    honestly no reason to run an aftermarket maf. get a fixed afc from zzp and be done with it. thats what im currently running...24psi. no issues.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  8. #48 Re: Just got a turbo kit, couple quick questions
    I break stuff selliott's Avatar
    Kansas City
    I like how I got dragged into this lol
  9. #49 Re: Just got a turbo kit, couple quick questions
    Quote Originally Posted by selliott View Post
    any time pal.
  10. #50 Re: Just got a turbo kit, couple quick questions
    Kansas City
    My thread is full of what not to do things
  11. #51 Re: Just got a turbo kit, couple quick questions
    why its a great tool to have here lol
    you do have the how to kill a tranny job all wrapped up.
  12. #52 Re: Just got a turbo kit, couple quick questions
    Kansas City
    I try lol
  13. #53 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    Quote Originally Posted by NebTurboST5 View Post
    exactly, stock maf with some sort of afc is all you need.
    x2
    2009 Challenger SRT8
    Expert at being gay.
  14. #54 Re: Just got a turbo kit, couple quick questions
    Quincy, Mass
    I went with a ported l67 tb, l26 upper and lower, and stock maf with an afc. Any maf you go with will require a retune. If you go lt or ls you can get a maf block off plate for the stock tb.
    Air is being pushed in the by the turbo as apposed to sucked in by the supercharger so you don't need a big throttle body unless you have a really big turbo.
    Oh Ya it never ends...
    No more GP 04 Impala SS Indy:
  15. #55 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    That's been my understanding, no big TB needed. Boost is boost and does the trick.
  16. #56 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    Ported L67 TB is what I'm using too.
  17. #57 Re: Just got a turbo kit, couple quick questions
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Stock l67 TB for me and LT1 MAF, LT1 MAF is cheaper than an AFC if we want to get back to the saving a few dollars factor and is all I've ever needed and like said above anything other than stock needs tuning anyway. Oh yeah my car has been turboed and on this setup since 2005...not many can claim that.
  18. #58 Re: Just got a turbo kit, couple quick questions
    Sep 2015
    Richfield
    I'm loving the turbo input right now, just saying 😀
  19. #59 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    I wanted a HPT tuner, however I ended up finding a used DHP that I got a really good deal on, so I guess I'll be using that. I figure if I don't like it, it shouldn't lose value. Should be here Friday. If I have a tuner, do I still need a scangauge? Thinking about going with this Wideband:
    https://www.amazon.com/gp/product/B0...A1OSQ3YK654B89
    I read that DHP scanning software is awful and to use UV scan instead, so I plan to do that. Will I be able to log this at the same time?
  20. #60 Re: Just got a turbo kit, couple quick questions
    dhp scans just fine. its how long it takes to save thats a issue for some. uv scan is separate program that uses the dhp interface to log with.
    that wb will work.
  1. Couple of quick questions
    By SpecialK in forum Introductions/Noob Questions
    Last Post: 01-15-2015, 08:14 PM
  2. Couple quick questions
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 06:30 PM
  3. couple of quick questions about tstats
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 02-02-2010, 11:05 AM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. couple of quick downpipe questions.
    Last Post: 03-18-2009, 07:36 PM
