Thread: GXP rims on a GT
Results 1 to 10 of 10
  1. #1 GXP rims on a GT
    Nov 2018
    Detroit
    Chats
    I bought a 2005 gtp today with GXP rims and the car needs new tires.. I know the gxp uses different size tires on the front and back. What size should I put on my gtp? Should i put all the same size ?
  2. #2 Re: GXP rims on a GT
    Oct 2011
    Toledo, OH
    Chats
    956
    Check to make sure you actually have 2 different sized rims first. People like to swap them to have 4 of the same size when putting them on other cars.
    You can run all the same tire even if they are staggered. I don't know what the best tire is for that, but I know it's been brought up on here before.
    7"
  3. #3 Re: GXP rims on a GT
    Nov 2018
    Detroit
    Chats
    Same size rims. They are the GXP rims. Tire size is all the same st the moment 345-45-18.
  4. #4 Re: GXP rims on a GT
    Kemmerer, Wyoming
    Chats
    60223
    are you sure it's a 345? i'm willing to bet you meant to say 245. if that's the case I would stick with that size because it's way more common than the size on the actual GXP. ask me how i know.
  5. #5 Re: GXP rims on a GT
    Oct 2011
    Toledo, OH
    Chats
    956
    Quote Originally Posted by GrandPrix1118 View Post
    GXP comes factory with 18x8 rims in front, but 18x7 rims in back.
    7"
  6. #6 Re: GXP rims on a GT
    Nov 2018
    Detroit
    Chats
    It has 245/45/18 s on it. Front and back. So if I have GXP rims. Just make sure the 18x8s are in the front ?? Also I think I have a GT. When I start it up. It says wide track on the screen. I believe it was top swapped with supercharger / heads
  7. #7 Re: GXP rims on a GT
    Oct 2011
    Toledo, OH
    Chats
    956
    It won't make a difference on a non-GXP, because GXP suspension is different, but yeah wider in front on a FWD. Being in Detroit, it's entirely possible you have aftermarket Alcoa "GXP" rims, as they are all over craigslist for a good price.
    GTP says "Widetrack" too. Does your info center have an "Engine Boost" page?
    7"
  8. #8 Re: GXP rims on a GT
    Chats
    83662
    245/45/18 is what you need to stay with for correct speedo read out.
  9. #9 Re: GXP rims on a GT
    Nov 2018
    Detroit
    Chats
    Yes. It says engine boost. Like when you hit the gas. The bar fills up. Other than that, nothing else about boost. The trunk says GT but the guy I bought it from said he replaced the trunk. What else are some signs that it’s a GTP or a GT?
  10. #10 Re: GXP rims on a GT
    Oct 2011
    Toledo, OH
    Chats
    956
    The trunk has the RPO codes, so that's out.
    If it's got a supercharger, it's probably factory. Look at the intake and manifolds. Topswaps are a lot of work, you wouldn't do one and not upgrade those too. If it was sold to a dealership, the VIN wouldn't match the engine type either and might raise some flags.
    7"
  1. Wtb gxp rims or aftermarket rims
    By pontiacgt500 in forum Wanted To Buy - Parts
    Last Post: 01-15-2017, 11:37 PM
  2. Rims rims and more rims for saleeeeeeee
    By GTPSHAWTY in forum For Sale - Parts
    Last Post: 09-21-2013, 10:10 PM
  3. Interested in changing my 04 grand prix gt rims for the Gxp factory rims
    By holt149 in forum Visual/Body Modifications
    Last Post: 02-21-2011, 01:41 PM
  4. 06 GP GXP Rims?
    By aries83 in forum Tires & Wheels
    Last Post: 10-26-2009, 01:41 PM
