Thread: CV Shaft
Results 1 to 15 of 15
  1. #1 CV Shaft
    GTX Level Member webracin's Avatar
    Arkansas
    Chats
    I recommend going to Oreilly's Auto Parts for the CV shaft if you are wanting to go with a stock replacement. For the Grand Prix they are about $80.00 to $90.00 depending on which side. This is for New, not Remanufactured CV shafts made by A1 Cardone. There is a 5.00 core when you buy the new shafts. Remans by A1 Cardone are about $60.00, but there is a $50.00 core charge.
    Part Numbers
    Left Side (drivers) .................................................. ..66-1255
    Right Side (Passengers) non-supercharged................66-1250
    Right Side (passengers) supercharged.......................66-1256
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: CV Shaft
    SE Level Member SDGrandPrixGT23's Avatar
    San Diego, California
    Chats
    Just curious but why are S/C pass. one's more expensive? I know the nose and what not are on that side but I didn't think there was much of a difference in the GT and GTP's
  3. #3 Re: CV Shaft
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Chats
    it's probably due to popularity-- only the gtp/regal gs use that part.
  4. #4 Re: CV Shaft
    Arkansas
    Chats
    I would have to say that Toasty is probably right. The reason it's different is due to the Heavy Duty Differential. So, (and I am just throwing numbers out) if 30% of cars use the GTP shaft, and 70% use the GT shaft, the cost for manufacturing the shaft will be split among each group, and since there are more GT's out there than GTP's, its cheaper for the GT.
    webracin
    2001 Grand Prix GTP
  5. #5 Re: CV Shaft
    SW Chicago Suburbs
    Chats
    Quote Originally Posted by webracin View Post
    I would have to say that Toasty is probably right. The reason it's different is due to the Heavy Duty Differential. So, (and I am just throwing numbers out) if 30% of cars use the GTP shaft, and 70% use the GT shaft, the cost for manufacturing the shaft will be split among each group, and since there are more GT's out there than GTP's, its cheaper for the GTP.
    webracin
    i think you mean for the GT
  6. #6 Re: CV Shaft
    Saraland Alabama
    Chats
    Advance has the same shaft with no core charge, last one I bought (for my father in laws car) was the same price as o reilly (o reilly had to special order them)
  7. #7 Re: CV Shaft
    Arkansas
    Chats
    Quote Originally Posted by Toasty View Post
    Good Catch Toasty.....I fixed it
    2001 Grand Prix GTP
  8. #8 Re: CV Shaft
    Donating Users Burgundyman's Avatar
    Chats
    I am still at odds as to why there is such as big spread...You have to wonder that the OEM though pricey must be superior and should last more than one year...Just a pain to have to replace them under a year even if O'Reillys gives you a new one under warantee...Just my two bits...50-90 is better than 550 from the dealer.
  9. #9 Re: CV Shaft
    Donating Users Curtis's Avatar
    Missery
    Chats
    51
    You can get them at NAPA also, $59.00 no core, usually one day to get them if not in stock. But I got mine at Auto Zone for $69.00 + core, but I took my old ones in when I got mine, limited lifetime warranty!
  10. #10 Re: CV Shaft
    SE Level Member BlackGS's Avatar
    Central Jersey
    Chats
    I bought my axles from wbodystore.com:
    Halfshafts (HD & Non-HD transmission)
    My opinion is that these axles are an upgrade to any OEM replacements, and still only $75 for either side with no core to worry about.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  11. #11 Re: CV Shaft
    Chats
    Quote Originally Posted by BlackGS View Post
    But then there is shipping which is just like a core charge
  12. #12 Re: CV Shaft
    Central Jersey
    Chats
    Shipping from WBS for me is $17 with no tax. Core charge at Napa is $56 with $7 tax. Napa axles are still OEM with the inferior band clamps.
    Looks like a lot of places just raised the price of axles. WBS is now $85 for either side new, and Napa is $87 for left / $114 for right, or $51 remanufactured with core.
  13. #13 Re: CV Shaft
    Barksdale AFB, LA
    Chats
    I bought brand new (not remanufactured) A1 Cardone axles (same as listed above) from RockAuto for $125 shipped. That includes both axles.
    RockAuto is one of the best places to get OEM style parts, period.
    2009 Subaru Impreza WRX STI
  14. #14 Re: CV Shaft
    SE Level Member deangtp's Avatar
    Kansas City, MO
    Chats
    I bought GSP axles from Advanced Auto parts. They are brand new not rebuilt axles. I asked and researched and they were cheap enough, so I bought them. I have a few track passes, how ever many times I have done hard runs and a couple runs well into triple digits. So far so good
  15. #15 Re: CV Shaft
    Saraland Alabama
    Chats
    the gsp ones are the same thing as the cardone (I have put them in a few different cars, and a few had cardone lables under the gsp)
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. CV Shaft Rebuild/Replace [*]
    By Reptile in forum How To Write-Ups/Tech Tips
    Last Post: 11-06-2009, 02:04 PM
