Thread: Local Shortened Dog Bones
Results 1 to 20 of 21
  1. #1 Local Shortened Dog Bones
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Chats
    Credit for this info goes to TehGTP. I just did some research and gave it a try, and wanted to share with others.
    So your in the market for some shorter dog bones ZZP'S price is $27.99 (w/o shipping) and Wbody Stores is $25.99 (w/o shipping)
    So here is the solution Check Autozone, AdvancedAuto, O Reilly Auto Parts, etc... the price is about $12 per mount ( or around here that is the price, it may be different in other states)
    Part #2899 they are top torque struts for 2001 Pontiac Aztek and they work out great.
    So lets do the math $12+$12=24 WOW!!! your already saving, and no shipping charge so you save on that also
    Hope this helps some people out.
  2. #2 Re: Local Shortened Dog Bones
    Becca Boo MizzBecca's Avatar
    Michigan
    Chats
    3136
    I can't even begin to tell you how much this thread saved my life.
    I drive a POS
  3. #3 Re: Local Shortened Dog Bones
    Wausau, WI
    Chats
    Quote Originally Posted by MiZzBeCcA View Post
    ................wow
  4. #4 Re: Local Shortened Dog Bones
    Michigan
    Chats
    3136
    Quote Originally Posted by Liquifire View Post
    ................wow
    Lol
    I drive a POS
  5. #5 Re: Local Shortened Dog Bones
    Houston, TX for now
    Chats
    Thank you!!!
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  6. #6 Re: Local Shortened Dog Bones
    Houston, TX for now
    Chats
    I just went down to Autozone to pick some up and here in Texas and online they are $24 for one. So I looked up Rockauto and just bought a pair shipped for $17.50. I love Rockauto. And thanks again for the part number.
  7. #7 Re: Local Shortened Dog Bones
    Jersey
    Chats
    1002
    wow, i wish i knew this before i bought the zzp units. They didn't even fit anyway, they were crooked
    16' wrx sti- stock
  8. #8 Re: Local Shortened Dog Bones
    Aug 2008
    Long Island, New York
    Chats
    this is good info... what exactly is the effect of shortened dogbones? and wow im actually glad that worthless piece of crap Aztek came out just for this reason
  9. #9 Re: Local Shortened Dog Bones
    Houston, TX for now
    Chats
    Quote Originally Posted by 2000GTP View Post
    They roll the engine forward thus moving the gravity center of the engine forward. For car with lowering kits it helps return the motor position closer to stock so that everything lines up better. At least that is what I think I read.
  10. #10 Re: Local Shortened Dog Bones
    Donating Users
    Plainfield, IL
    Chats
    how much shorter are these then stock?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  11. #11 Re: Local Shortened Dog Bones
    St. Louis
    Chats
    Quote Originally Posted by gotboost3 View Post
    these are 1" shorter then stock, if i get around to it tomorrow i will take a pic of them compare them to the stockers
  12. #12 Re: Local Shortened Dog Bones
    Donating Users
    Plainfield, IL
    Chats
    sweet good find ....ill buy these when i finally get around to lowering my car or just install them now since my rims set my car an inch lower
  13. #13 Re: Local Shortened Dog Bones
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Chats
    Wow that's pretty cool. Thanks for postin this. If my car isn't lowered would gettin these shorter ones make any diff?
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  14. #14 Re: Local Shortened Dog Bones
    Donating Users
    Plainfield, IL
    Chats
    Quote Originally Posted by superv6 View Post
    not really its to cure vibrations when lowering which i have alot of and im only sitting .5 - 1.0 inch/es lower than stock....
  15. #15 Re: Local Shortened Dog Bones
    Chats
    77762
    If you have the Pacesetter's you can't run shortened dog bones AND lower your car...the movement and new placement of the motor will put the 3-bolt flange right up against the floorboard and grind against it all day long...trust me. I know.
  16. #16 Re: Local Shortened Dog Bones
    Donating Users
    Plainfield, IL
    Chats
    damn really...but doesnt lowering your car put the downpipe farther from the floor board...liek the motor is tipped more backward? and the dogbones compensate for this?
  17. #17 Re: Local Shortened Dog Bones
    Jersey
    Chats
    1002
    shorter dog bones... If you want to do it right get spacers to get rid of vibrations. Alot of guys melted their rad fans by having their exhaust manifold/header to close from the shorter dog bones tilting the motor more forward.
    16' wrx sti- stock
  18. #18 Re: Local Shortened Dog Bones
    Donating Users
    Plainfield, IL
    Chats
    Quote Originally Posted by 99prixgt View Post
    cradle spacers or motor.tranny mount spacers?
  19. #19 Re: Local Shortened Dog Bones
    St. Louis
    Chats
    i believe he is talking about these ZZ Performance
  20. #20 Re: Local Shortened Dog Bones
    Jersey
    Chats
    1002
    Quote Originally Posted by stlmo_gtp View Post
    yeah thats what i was talking about. Vinnie makes better ones, the zzp ones don't allow alot of thread for the bolts.
    16' wrx sti- stock
  1. modded dog bones
    Last Post: 03-28-2009, 02:24 AM
  2. Shortened dog bones
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2008, 10:21 AM
  3. Are these the moutns/dog bones I want?
    By Street Wolf in forum General Tech Discussion
    Last Post: 01-11-2008, 09:08 AM
