Thread: Transmission or Shifter problem....?
Results 1 to 2 of 2
  1. #1 Transmission or Shifter problem....?
    Oct 2015
    Milwaukee
    I have a 1994 Grand Prix with a 3.4 with 98k on it. The car starts, shifts and drives most of the time with no problems. What happens is the car will not go into gear. I have to keep moving shifter back and forth thru the gears and then it seems to catch, sometimes in reverse, sometimes in drive. This can happen in 5 minutes or 45 minutes, but once that happens its good to go, can drive everywhere with no issues, trans shifts fine. But as soon as I put car back into park I have the same problem no matter if its 1st thing in morning or after its warmed up. A friend mentioned to me about the parking prawl? Starting to pull console apart... Any help would be appreciated
  2. #2 Re: Transmission or Shifter problem....?
    Look at the linkage at the transmission. If you don't have a loose cable or something silly.. it's going to be bad.
  1. 97 GP GT, shifter not moving transmission lever.
    By penright in forum General Tech Discussion
    Last Post: 06-24-2013, 01:27 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. weird shifter problem
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-21-2012, 01:54 PM
  4. Shifter electrical problem
    By x24motox in forum General Tech Discussion
    Last Post: 06-09-2011, 06:24 PM
  5. shifter/ ignition switch problem?
    By Flut in forum General Tech Discussion
    Last Post: 05-04-2009, 10:31 AM
