Thread: The defacto guide to tuning your car for e85.
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 201 to 220 of 225
  1. #201 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Now I am at 1.3401 cylinder gain. Injectors fuel flow is from “53.3up to 63.9” manifold vacuum. still won’t keep it running
  2. #202 Re: The defacto guide to tuning your car for e85.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Make sure the vacuum lines going to your fuel pressure regulator arent leaking, or collapsed . While doing that make sure you dont have a vacuum leak of some sort.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #203 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    All vacuum lines are good.
  4. #204 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Everything seems okay vacuum line wise and part wise. It’s got to be something tune wise. Can’t figure this out Geez!!!!
  5. #205 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Should I put it right back at stock injectors setting? 60# setting isn’t running it.
  6. #206 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    Email me your tune.
    nick_04sc@hotmail.com
  7. #207 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    Your tune looks good.
    You've got a problem elsewhere if the car won't run. Try unplugging the maf and see if that makes a difference.
  8. #208 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks for looking bro!
    I tried starting it with the (85mm) maf unplugged And it started I let it ran for a while. Then I plugged it in and it jumbled a little then smoothed out. With it plugged in I restarted and stopped it many times and it ran satisfactory! It has some odd pending generic codes that I need to check out. I’ll be driving it out out the street, Hopefully soon and I will keep you updated. I’m still a bit off from my brain procedures.
  9. #209 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok the 85mm maf setup will not work properly. If I plug it in it idles roughly. So the 85mm is a no go. I put in stock maf and it idles fine. I went to get fuel and it drove perfect with the stock setup. Idles great in reverse and drive. So, so far it is driving good as is.
  10. #210 Re: The defacto guide to tuning your car for e85.
    if you change the maf you would need to use a maf file for said maf, then fine tune it to you're car.
  11. #211 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    How do I install the file for the 85mm maf? I have 85mm maf but it would not run properly. *The stock maf is running good as is!
  12. #212 Re: The defacto guide to tuning your car for e85.
    stock maf is fine as long as your not out flowing it yet.
    you need to change the maf hrtz file. not sure what car that maf came from but thats the place to start. find its bin file, and copy it over. the wide band is key to fine tuning it.
  13. #213 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    I didn't realize you have a different maf. You definitely need to change your maf table then.
  14. #214 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I took out the 85mm. I will do a scan to see if I’m outflowing the stock maf. I need to know how to change the maf file. Can one of you give me instructions on how to redo the maf file!
  15. #215 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    This sucks. I really have a very hard time remembering any of the procedures of tuning. I’m trying to find any written how to procedures on here.
  16. #216 Re: The defacto guide to tuning your car for e85.
    May 2008
    Schuyler, NE
    What is the maf out of?
  17. #217 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
  18. #218 Re: The defacto guide to tuning your car for e85.
    thats the lq4 maf. ive got that file. hell maybe i set it to ya already.
    open your tune, then open the tune with the file as a compare file. go to airflow iirc and you'll see the maf button. open it, then hit the middle of three windows to see the new file, click the top left of the file to highlight it all, right click, copy, then hit the left window back to your tune highlight it all, paste. then save the file, save as. "rename it"
  19. #219 Re: The defacto guide to tuning your car for e85.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m not really catching how to do that. My email is rickisrad04@yahoo.com
  20. #220 Re: The defacto guide to tuning your car for e85.
  1. HKS: Beginners guide to tuning
    By matt5112 in forum General Tech Discussion
    Last Post: 09-22-2012, 10:09 AM
  2. Gary's tuning guide?
    By Sandman in forum PCM Tuning
    Last Post: 03-23-2011, 06:53 PM
  3. gtp buying guide
    By windycitygtp in forum General Tech Discussion
    Last Post: 01-18-2009, 09:09 PM
  4. The Compleate Fuel Economy Tuning Guide
    By TDCRacing in forum PCM Tuning
    Last Post: 07-09-2008, 11:43 AM
