Thread: Any Good Tuners In The Chicago Northwest Suburbs area?
Results 1 to 13 of 13
  1. #1 Any Good Tuners In The Chicago Northwest Suburbs area?
    SE Level Member G8GTChick's Avatar
    Naperville, IL
    I need a good tuner to fix my 2000 GTP tune that was replaced by a much worse one for some apparent reason, it runs a lot more sluggish now. It has the basic 3.4 setup. If someone knows of anyone that, please reply here or PM me. Thankie
  2. #2 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    new to the GP's what is meant by tuning
  3. #3 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Mar 2012
    NC
    Quote Originally Posted by lewis1952 View Post
    Tuning is changing the values inside the computer that controls how the engine and transmission operate. By altering these values, you can get more power and better fuel economy.
  4. #4 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Nov 2013
    Boulder Hill, Illinois
    Bump......Wondering the same thing, hopefully there is a tuner in the suburbs, need mine tuned asap!
  5. #5 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Sep 2013
    tulsa okla
    thanks Sven
  6. #6 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Feb 2009
    flintnasty MI
    I would suggest going back to stock if you are having issues.
  7. #7 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Naperville, IL
    Bump... I got the bin that was put on last, apparently it's a 98 GTP ZZP pcm that was on there to begin with. Still looking for a good tuner who knows these cars well that can help me out. Thanks!
  8. #8 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    hangover park IL
    I find a lot of time people think that the tune will fix issues that are mechanical/electrical failures
    are you sure your car is in tip top shape?
    ~James~ Psychotic Gearhead
  9. #9 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Donating Users moddman's Avatar
    Midwest
    That would be the best route as recommended by a well-known out-of-state tuner I deal with.
    He said go to stock year bin and take it from there. Just be careful not to romp on it at all.
  10. #10 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Naperville, IL
    Quote Originally Posted by Turbocharged400sbc View Post
    Well, I noticed off a dead stop it skips or vibrates before it picks up and it got much worse with the tune on there now but I was hoping it wasn't a trans issue.
    For the most part, it was running much better on the tune that was on there before the current one. I was told it was the same tune and the previous one could have been a "bad burn" because the fuel trims were much worse than the current burn. I don't see how that makes sense if it was running like a champ before. I just need someone to check it out that knows what they're doing.
    Also, I was told you can tune out the trans pressure or whatever, is this true?...
  11. #11 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    hangover park IL
    Sounds like what you're describing is the trans shudder from a bad input clutch / direct clutch drum seals.
    I'm afraid it may be time for you to consider a new transmission.
    what more than likely happened is that with your old tune all of the transmission adaptives, which had been learned line pressure had been maxed or near it.
    when the car was reflashed it lost all of the learn'd adaptives and that's why the problem is worse because it hasn't compensated yet.
    you can play with the pressures but its not the pressure that's the problem it's the seals for the clutch seals
  12. #12 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    im in appleton Wisconsin
    __________________________________________________ __________________________________________________ ______________________stage 3 zzp heads,sd headers,ss m90 kit,3in cat back,AEM wide band,cai,evap egr rear 02 delete.
  13. #13 Re: Any Good Tuners In The Chicago Northwest Suburbs area?
    Midwest
    [QUOTE=Turbocharged400sbc;1200859
    when the car was reflashed it lost all of the learn'd adaptives and that's why the problem is worse because it hasn't compensated yet.[QUOTE]
    Actually, It depends on what flash was used, if it was a partial flash, then it would not have lost the adaptive trans settings. On the flipside, if it was a full flash then yes, it would have reset the adaptive trans settings completely.
    I agree. Sounds like a new trans with all the needed updates should be a good idea. Contact Tim King.To get in contact with Tim King email him:
    Bad3800@aol.com
    it will cost you a little over 2K He's good
    Triple Edge Performance - Home Page
    http://shop.zzperformance.com/store/...nsmission.aspx
    Price: $2,199.99
  1. tuners in northwest illinois eastern iowa
    By izup69 in forum Midwest
    Last Post: 08-29-2011, 08:01 PM
  2. south chicago suburbs/ NWI
    By iroc2 in forum Midwest
    Last Post: 07-15-2010, 09:40 PM
  3. Who here has a red GP that live in Chicago NW suburbs?
    By Freebeer187 in forum Off Topic Discussion
    Last Post: 09-04-2008, 03:31 PM
  4. Anyone with a tuner in nw suburbs of chicago?
    By Freebeer187 in forum Midwest
    Last Post: 08-19-2008, 06:40 PM
