Thread: Pcm
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: Pcm
    Chats
    243824
    wrong maf is not gonna work well long term. the 98 maf likely wont sit in the 99 tb right either.
    do the security learn yet, at least the 10 seconds key to run then off yet?
  2. #42 Re: Pcm
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Chats
    Yea I did it 3 times and still didn't crank on the 3rd try but battery was somewhat dying but I put in a charger will try again tomorrow will rescan for codes tomorrow
  3. #43 Re: Pcm
    Chats
    243824
    when you do it voltage must stay up, so charger on it, do not open the doors or power the radio or windows. i like to open the d/s window reach in, turn the key hit the timer and walk away, this way your not trapped in the car the whole time.
    e brake on to to kill the parking lights.
  4. #44 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    Yea I was doing that but ima look into the crank sensor due to me not knowing the condition of it ik the motor runs but it sat for a year
  5. #45 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    Trying the security relearn got battery charger going window down time set key in ignition next will b the cranK sensor
  6. #46 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
  7. #47 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    What if fuel slow8fills up at the shreader valve
  8. #48 Re: Pcm
    Chats
    243824
    engrish please. proof read your posts....
  9. #49 Re: Pcm
    Apr 2015
    Columbus, OH
    Chats
    246
    Think he meant his Schrader valve is leaking? Can those be replaced like a tire valve, or do u need a new fuel rail?
    Top Swapped 01 Imp
  10. #50 Re: Pcm
    Chats
    243824
    they unscrew just like a tire valve stem. o ring at the bottom might be torn, or you just need to wiggle the pin around till it seals up again. ive had to do the wiggle deal on my own rail once.
  11. #51 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    T bgg e valve is leaking bad and changed out the crank sensor still no start but will try to change out the oring or the rail itself
  12. #52 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    Finally gave up and dropped the car off at meineke car care for a diagnostic on the car talked with the tech and he said something about the throttle body being clogged not letting the fuel ignite basically like the throttle plate but that was just a visual look before he pulled the car in just waiting for the final diagnosis to get this issue resolved
  13. #53 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    9 Pontiac Grand Prix.
    Inspection Results
  14. #54 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    Got the car started today swapped out the pcm with one from 01 special edition grand prix car started right up swapped zzp tuned pcm no start swapped back to donor pcm car started
  15. #55 Re: Pcm
    Chats
    243824
    you may have to do a security learn, zzp often sets it to key on for 10 seconds, then off. then try to crank it. should fire up.
    if not, key to run for ten minutes, off for less then 5 seconds, back to run for 10 minutes, you do that 3 times, 4 th time it should crank and fire up.
    use a timer, dont open the doors or use any power. if the battery sucks, put a charger on it. key to run for 30 minutes can beat up a good battery.
    i like to open the window, shut the door and work the key from out side the car. nothing worse then being stuck in the car for a 1/2 hr.
  16. #56 Re: Pcm
    Oct 2014
    portland oregon
    Chats
    507
    Unless you got some dank weed[emoji1787]
    Sent from my SM-N920V using Tapatalk
  17. #57 Re: Pcm
    Chats
    243824
    Quote Originally Posted by wowitsfast View Post
    id loose my mind even with the dankest weed. i walk away from it, come back at the 9 minute mark lol
  18. #58 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    I did all of that once before and no fix would prime the car 4x and crank did the security relearn and crank learn will email tim to see what could b done because it has to b In the tune because that's the cars stock pcm that was tuned
  19. #59 Re: Pcm
    Sep 2018
    Saint Louis
    Chats
    Some dank is the only reason I dealt with this car for si long if I didn't have any the car would of been sitting in a scrap yard burnt to a crisp
  20. #60 Re: Pcm
    Chats
    243824
    i still cant believe i sold mine and got like real money for it lol i miss it less and less as time passes. i had that car for 10 years. never in my life hung on to a car for that long. it never left me stranded, all tho it did blow up a couple times. worst was the tranny that just locked up. i was in my friends driveway. so i was not stuck any where bad lol even trucks i bought new i sold and re upped in 5 years time.
