Thread: sort out fuel trims
Results 1 to 20 of 21
  1. #1 sort out fuel trims
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hi all,
    Right now im running e85 on my stock injectors with a 3.5 pulley.
    I have been trying to sort out the fuel trims, but it just doesnt seem to be working.
    I unplugged my MAF and logged as suggested in the tunning for dummies how to.
    I went into Airflow and primary VE and adjusted each of the values the log gave me. When the fuel trim was 5% i added 5% to value in the table. When the trim was negative, i subtracted 5%.
    I went and logged today with the MAF plugged in and the LTFT seems like its even higher. Non of the values moved towards 0. I even parked, let the car idle and learn the idle LTFT values, went into the tune and added twice that amount to the table for those values, restarted and re logged and there was virtually no change. What am i doing wrong?
    I changed my fuel filter, it was pretty stopped up about 2 tanks ago. Should i try that again? I did max my injectors on this log which has never happened before. Maybe the new filter is clogged? or maybe all of the gas is out of the car?
    Some other details, the injector gain is set to 1.33
    here is a link to the log file and tune, my WOT pull is pretty much at the end.
    Update your browser to use Google Drive - Google Drive Help
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: sort out fuel trims
    Kemmerer, Wyoming
    Chats
    60223
    first things first: plug that maf back in and don't bother tuning your ve. the ve is only a backup and doesn't have any bearing on how the car will run unless the maf fails.
    edit: second: are you logging throttle percentage? you also need to be logging your O2 sensor. also, on the scan I downloaded, your maf table only shows one value, are you logging it right?
  3. #3 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Quote Originally Posted by SgtMarshal View Post
    I used whatever the stock setup was for the VCM logger.
    I will try and add the o2 sensor and the MAF table (i dont see one in the graph). I did see values change in the gauge area.
    I have no idea if I am doing this right. Where do i adjust fuel then if not VE? Which table should I be working with?
  4. #4 Re: sort out fuel trims
    Kemmerer, Wyoming
    Chats
    60223
    you add and take fuel away depending on your O2 sensor to your maf table. you need to follow the instructions in the "starting hp tuners" thread to set up your maf table.
  5. #5 Re: sort out fuel trims
    Kemmerer, Wyoming
    Chats
    60223
    scroll down to where it says this and follow the directions
    Now we are going to make some custom histograms to log what we want and make is easy to use. Starting with plotting LTFT's on to the maf table.
    To do this you will have to go into the primary table. The primary table shows what sensor are being logged by the scanner.
  6. #6 Re: sort out fuel trims
    Chats
    243824
    ill set lower maf if need be with ltft. stock maf you dont always need to touch down low. but up top you may have to. ill do a scan and watch maf hurtz and what the wb says. if you pause the scan and use the arrow keys to move ahead its like a second a click of the button,
    you need to set your pe afr to 1.200 and see where you land on the commanded, small amounts from there up or down with dial it in to where you want it, mid 11's.
    set pe enable to like 30% hot. so now you know when you see 30% throttle you should be in pe mode commanding the lower afr. now watch the wb as the scan goes, you want the wb to match the commanded, so if its not matching you look at maf hurtz and the wb and raise to add fuel, lower to remove fuel to those cells.
    i dialed my n* maf using this part of the scanner only pretty much.
    sort out fuel trims Attached Images
  7. #7 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I don't have a wide band o2 yet. I'm just trying to get my fuel trims down to + or - 4
  8. #8 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Guys, im sorry if i'm dense but what table should i be adjusting to increase or decrease fueling? Where do i Find the "MAF" table?
  9. #9 Re: sort out fuel trims
    Chats
    243824
    in airflow, then maf hrtz frequency
  10. #10 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I think ive gotten the scan right ... Should be obvious which log file it is. I just ran the car for a few minutes to check.
    If someone wouldnt mind taking a look: Update your browser to use Google Drive - Google Drive Help
    On another note:
    I will be chaning my injectors to the Deka 80#. How do i go about doing that? i recall reading that i need KPA ... zzp says the following Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 80 lb/hr = 630 cc/min = 850 cc/min Is that useful at all?
  11. #11 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I found the Flow vs KPA table, should i just enter 80? looks like the values change a bit based on pressure, should i just divide 80/33 and multiply the figures in the table by that?
  12. #12 Re: sort out fuel trims
    May 2008
    Schuyler, NE
    Chats
    265
    Yes, 80/33 and multiply your answer to the table.
  13. #13 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I have read that the idle with the 80s can be difficult on pump gas because they are so large, anyone else hear of this?
  14. #14 Re: sort out fuel trims
    May 2008
    Schuyler, NE
    Chats
    265
    They may idle a bit rich, but you should still be able to get them close. My buddy ran 95' and was able to idle around 14.
  15. #15 Re: sort out fuel trims
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I am installing all of my mods tomorrow. I have read that you can run a lot richer with e85 without loosing power, to help with cooling the charge etc. what table would i change to tell the car to run a bit richer? I would like to start out rich, and inch it back towards stock just for safety.
  16. #16 Re: sort out fuel trims
    Chats
    243824
    you dont want to be richer. set pe to 11.5, watch the wb to make sure its reading the same, if its not you add to the maf.
  17. #17 Re: sort out fuel trims
    May 2008
    Schuyler, NE
    Chats
    265
    What you read is correct. A richer afr with e85 doesnt decrease power the way it does with regular fuel.
    The easiest way to add fuel is with the base PE table. You can richen it up a full point, then slowly dial it back til you get to the afr you want.
  18. #18 Re: sort out fuel trims
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Chats
    131
    How imperative is it to log trims without disabling the Power Enrich? Asking for a friend.
  19. #19 Re: sort out fuel trims
    Kemmerer, Wyoming
    Chats
    60223
    I log trims all the time without disabling PE. it's dangerous to disable PE.
  20. #20 Re: sort out fuel trims
    Apr 2015
    Columbus, OH
    Chats
    246
    Quote Originally Posted by rickisrad View Post
    What do you even mean? I mean, can you clarify what you are trying to do? If you have no PE enabled, definitely dont take it over 7000ish hz. Are you trying to tune with narrowband?
    Top Swapped 01 Imp
  1. getting fuel trims dialed in
    By Timing in forum PCM Tuning
    Last Post: 04-21-2013, 10:13 PM
  2. Fuel trims
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-11-2011, 01:55 AM
  3. Help with fuel trims
    By 00gpgtp in forum PCM Tuning
    Last Post: 01-10-2009, 11:48 PM
  4. Jacked Up Fuel Trims w/Scan
    By Lawngoose in forum PCM Tuning
    Last Post: 11-18-2008, 11:15 AM
  5. VE Tuning and Reseting Fuel Trims
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 07-07-2008, 01:34 AM
