Thread: Verify HPT tune?
Results 1 to 16 of 16
  1. #1 Verify HPT tune?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hi Folks,
    I just tuned my car for e85 using the method in the sticky (i think) and filled it up with 14.5 gallons of Ethanol. Unfortunately my Gas gauge lied telling me the car was empty.
    Id love to have someone check the tune I did and see if i actually did what i was supposed to. (changing the injector gain by cylinder to 1.3)
    I am a bit skeptical because I flashed the car, realized the pump i was at was Out of order, and had to start the car and move to another pump. The car had not indication of being different.
    Another concern is that i adjusted the injectors to 1.25 to adjust for not being on pure ethanol. The LTFT was really high, like above 10 on my drive home.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. Likes bandook liked this post
  3. #2 Re: Verify HPT tune?
    The Boss Iceman6669's Avatar
    Jun 2011
    Chats
    74296
    You can add a copy of your tune to your post so that others can open it and see what it looks like to verify it for you.
    2011 F-150 Yote powered
  4. Likes bandook liked this post
  5. #3 Re: Verify HPT tune?
    Kemmerer, Wyoming
    Chats
    60223
    to tune for E85 you only change the cylinder gain to 1.3. do you have facebook?
  6. Likes bandook liked this post
  7. #4 Re: Verify HPT tune?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    here is a link to the file buick tuned maybe.hpt - Google Drive
  8. #5 Re: Verify HPT tune?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Quote Originally Posted by SgtMarshal View Post
    Unfortunately not. I deleted it a while ago, and havent looked back.
  9. #6 Re: Verify HPT tune?
    Kemmerer, Wyoming
    Chats
    60223
    so what did you change exactly?
  10. #7 Re: Verify HPT tune?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I think* I changed the injector gain by cylinder to 1.3. I fiddled with the fan turnon on and a few trans settings too
  11. #8 Re: Verify HPT tune?
    Kemmerer, Wyoming
    Chats
    60223
    I think it's running rich because of two things: one, you set your cylinder gain too high for the ethanol content of the fuel, and two, you still have gasoline in your system.
    I think you did it right assuming the ethanol content of the E85 is actually 85%, which I doubt it is. It was always 70% for me.
  12. #9 Re: Verify HPT tune?
    May 2008
    Schuyler, NE
    Chats
    265
    Give it some time. Ltft's should get closer to 0.
  13. #10 Re: Verify HPT tune?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I put about 100 miles on the car and fuel trims, especially under boost are reading in the positive. Under boost the car was showing 11%. I used HPT to clear the LTFT and it very quickly learned back into the positive.
    If i remember correctly positive fuel trim means the car is adding fuel right? that would mean its running lean. Could my fuel filter be clogged? i was running an e30-40 blend for about 2 tanks prior to the almost full e85 tank.
    I am just a bit worried about leaning the car out. I changed the injectors to 1.33 and it seemed to calm it down quite a bit. But that is way more than what my ethanol content should dictate.
    i added a quick log i took if anyone wants to take a look Update your browser to use Google Drive - Google Drive Help
  14. #11 Re: Verify HPT tune?
    Chats
    243824
    pos trims are lean. but wot your also locked in to pe mode, the trims just locked in what ever they were just before you entered pe.
    cant watch the scan now, its time to crash lol but you got the wb imported to the scanner as well?
  15. #12 Re: Verify HPT tune?
    Chats
    83662
    I'm all for whacking a table with fuel just to see if it does what I want.
    So say you are still running positive trims of +10%. In this case I'd smack the whole MAF curve with 3% worth of fuel, reset the trims and see how much closer the trims get to 0%. My hunch is that you'll get down to around +4 to +6% give or take with the fuel added.
    Once I know it's working, in most cases I use the wideband to find tune everything from there.
  16. #13 Re: Verify HPT tune?
    May 2008
    Schuyler, NE
    Chats
    265
    1.34 is about what you should set cylinder gain to.
  17. #14 Re: Verify HPT tune?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Do i need a wideband to run corn? My plan right now is to replace the fuel filter today, (the tank will almost be empty) fill up with e85 again, and then start dialing in the injector settings starting at 30. Then ill dial in the LTFT.
  18. #15 Re: Verify HPT tune?
    Chats
    243824
    set your injectors and leave them alone. tune the maf, and it dont matter if your stock or modded, if your tuning wot, you need a wb.
  19. #16 Re: Verify HPT tune?
    Kemmerer, Wyoming
    Chats
    60223
    you need a wideband to dial in your wot runs. if you set your injector duty cycle right then you won't need to mess with your maf, at least for adjusting for E85
  1. Replies: 18
    Last Post: 10-30-2017, 12:54 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. Close to having everything for my top swap, can someone verify all this for me?
    By hockeybawler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-02-2013, 01:25 AM
  4. how to verify mileage
    By SPONTSZ in forum General Tech Discussion
    Last Post: 10-12-2010, 10:31 PM
  5. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
