Thread: What do i do first?
Results 1 to 5 of 5
  1. #1 What do i do first?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I ordered HP Tuners. It should be here tomorrow. I want to tune the car for an e50 blend because i have e85 available locally, and I have KR on my current setup. Once I get some bigger injectors, I will go full E85
    Currently im running a blend around e30. and im still seeing KR. (mods: DP, 3.5, 180tstat, K&N drop in, Autolite 104s)
    What I am trying to figure out is what to do first.
    1. use the method in the Ethanol tuning guide to set my fueling ~115%, THEN work on tuning the car, dialing in timing, fuel trims etc.
    Or
    2. Get the car back on pump gas, deal with timing and fueling, THEN switch it over to e50, and fiddle with timing etc.
    FWIW, im seeing ~3* KR at wot, and some odd spikes at lower boost/ rpm. on pump gas 93, im seeing 7-8
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: What do i do first?
    Kemmerer, Wyoming
    Chats
    60223
    first thing I would do if you want to get rid of the kr is see where the kr shows up, then pull timing from those cells.
    I would use the cylinder gain method to tune for the E50 ish or whatever you want to run. scan for injector duty cycle and see how much headroom you have with your fuel, then if you aren't at 100% IDC, up the ethanol percentage. I bet you can run full E85 on stock injectors with a 3.5 pulley, but the only way to find is to try it.
  3. #3 Re: What do i do first?
    May 2008
    Schuyler, NE
    Chats
    265
    You probably can run a 3.5 on stock injectors with e85. Even if your idc does hit 100% or more, it's still not the end of the world. They can still supply enough fuel.
  4. #4 Re: What do i do first?
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I think im on about a 30% blend right now, and my IPW was 17ms I think? it goes to 25. if so, that gives me a solid 30% overhead (is there any way to see a percentage in hpt?)
    I wonder what kind of pulley i can drop to once i get injectors.
  5. #5 Re: What do i do first?
    May 2008
    Schuyler, NE
    Chats
    265
    Ipw by itself means nothing.
    You can scan idc with hpt.
