Thread: AFR Error will not work.
Results 1 to 20 of 21
  1. #1 AFR Error will not work.
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Chats
    I recently wired my wideband into my egr wiring harness and I have the normal AFR working but for some reason i can not make the AFR error give me any data at all.
    Imgur: The magic of the Internet
    AFR Error will not work. Attached Images
  2. #2 Re: AFR Error will not work.
    Chats
    243824
    did you set up the error maths?
    this is ls based, but you cant see what hes doing and make it work, how i got mine working. HP Tuners 3 0 VVE Scanner and Error setup - YouTube
  3. #3 Re: AFR Error will not work.
    Chats
    243824
    dint see both pics before.
    looked at my set up, in column im using manifold absolute pressure in KPA
    and rows is et to rpm's. engine speed sensor.
    in your maths set up window the units drop down, mine is set to "one 0"
  4. #4 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    Im trying to use the AFR Error to adjust my maf tune will that set up still work or is that only for VE tuning?
  5. #5 Re: AFR Error will not work.
    Chats
    243824
    thats just for VE tuning.
    maf tuning you can use long term fuel trims for idle and cruise, but for wot you tune off the wideband.
  6. #6 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    I understand that but couldnt i tune WOT using the MAF with the wideband?
  7. #7 Re: AFR Error will not work.
    Chats
    243824
    yes exactly what you want. my scanner set up for maf vs wb
  8. #8 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    That looks just like what what i have could I possibly see the user defined math you are using for the parameter in that chart?
  9. #9 Re: AFR Error will not work.
    Chats
    243824
    the 9.7 there would be a 10 but i had to play with it a bit to make it match the scanner vs the gauge.
  10. #10 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    Imgur: The magic of the Internet This is the math for the Wideband error. the other math for setting up the wideband is exactly how mine is and just logging my airfuel ratio works fine. I cant get any logs when it comes to the error
  11. #11 Re: AFR Error will not work.
    Chats
    243824
    mine looks a bit different.
  12. #12 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    Do you use that to tune your VE table or your MAF?
  13. #13 Re: AFR Error will not work.
    Chats
    243824
    i did for my tahoe i VE tuned it some. same math. im just maf tuned on the regal. been thinking of toying with it on the regal but lack the caring to do so. i set it all up in the scanner so im 1/2 way there if i want lol
  14. #14 Re: AFR Error will not work.
    Chats
    243824
    and my maf tuning is all ass backwards cause i spray meth. its got fuel removed more then anything else lol
  15. #15 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    So if i set up my AFR error table like the way yours is set up i would be able to Maf tune my GP using the data acquired within that graph?
  16. #16 Re: AFR Error will not work.
    Chats
    243824
    Quote Originally Posted by chrisrexmandie View Post
    those two are what i use for maf vs wb.
    dont need the wb error for maf tuning at all. just VE tuning.
  17. #17 Re: AFR Error will not work.
    Sep 2018
    NC
    Chats
    Hmmmm looks like the only thing different with your WB error vs Maf chart and mine is the error math i will change mine and see. It was strange how i was getting no data at all. I was told in order to tune using the maf you needed a wideband one you get to a certain HZ because then your fuel trims no longer play a role in the fueling. Was i told wrong?
  18. #18 Re: AFR Error will not work.
    Chats
    243824
    thats right, once you enter PE mode what ever throttle percent your set to it no longer uses the ltft's and runs off the pe file, if you zero'ed out the time vs rpm folder you"ll need to maf tune up top for sure. it will run lean on ya before a 1/4 mile is up if you dont.
  19. #19 Re: AFR Error will not work.
    Chats
    243824
    i also log the commanded AF and the wb AF as well as the WB err in the charts area. in my bottom row of charts, you can see em in the pic there.
  20. #20 Re: AFR Error will not work.
    Kemmerer, Wyoming
    Chats
    60223
    I think I used the predefined maths to get mine to work. and i'm also wondering why the thread was created today but the date shows as last year.
  1. Replies: 2
    Last Post: 05-15-2016, 05:42 PM
  2. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  3. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  4. Remote start - Used to work great now after some messing around it does not work.
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2012, 11:24 AM
  5. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
