Thread: Case relearn
Results 1 to 12 of 12
  1. #1 Case relearn
    Mokena IL
    Hello,
    I performed a top swap on my 06 GP about 2 years ago. Since I've done the top swap I have only been able to pass emissions once. I keep getting a random misfire DTC P0300 and it will some times set the CEL. It comes and goes; I even reached out to Turbo Tim at ZZP and he advised that I would need a case relearn. I am trying to avoid having drive from Mokena IL to Grand rapids Michigan to have it performed.
    Is there any one in the Chicago land area who has a VCM suite that can connect and perform the relearn for me? Name your price as long as it is reasonable. I have contacted the local chevy dealer Phillips in Frankfort IL and they quoted me 300 bucks. I contacted Cadillac in Matteson IL and they quoted me 124 bucks. I tried to explain to them what I needed and everything I said went right over there head.
    Thanks and much appreciated.
  2. #2 Re: Case relearn
    Damn, a case learn takes literally 20 seconds to perform and they want to charge that much LOL.
    Anyone with hp tuners or an aeroforce can perform this. Maybe someone is near you.
  3. #3 Re: Case relearn
    Aug 2013
    McDonald PA
    Steven gtx hall is. He is one Facebook too. Stevegtx iirc on here
  4. #4 Re: Case relearn
    Donating Users Uno99's Avatar
    Appleton, Wi
    Looks like Grand Rapids is closer than me just south of Greenbay, Wi. There has to be some more Chicagoland members out there that can help. Im sure they will chime in soon.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  5. #5 Re: Case relearn
    Mokena IL
    Thanks for the input so far guys!!
  6. #6 Re: Case relearn
    Aug 2013
    McDonald PA
    Edit the guy I said is in Chicago land area
  7. #7 Re: Case relearn
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    DHP can do it too. I just did one and it took about a min.
    Don't pay that much. They would rip you off. Have someone local like stated
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #8 Re: Case relearn
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    That blows!
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  9. #9 Re: Case relearn
    Nov 2013
    Wisconsin!
    Good god. Someone by you must have a newer areoforce......I'd do it for free if I was closer.
  10. #10 Re: Case relearn
    Appleton, Wi
    Im up in Appleton Wi with HPTUNERS if you ever happen to be up this way.
    Sent from my SM-G920V using Tapatalk
  11. #11 Re: Case relearn
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    a snap on solus pro scanner will also do a case learn. chances are one of your local garages will have one. as ffdp pointed out it takes less than 30 seconds. the garage never even charged me to do mine. i gave the guy 10 bucks anyway.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  12. #12 Re: Case relearn
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    If you ever make it down to stl I can do it. lol
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  1. Case relearn
    By GTPJIM in forum PCM Tuning
    Last Post: 08-25-2015, 07:31 PM
  2. case relearn how to.
    By hollas13 in forum PCM Tuning
    Last Post: 09-08-2013, 01:58 PM
  3. case relearn
    Last Post: 09-07-2013, 11:41 AM
  4. case relearn how to.
    By hollas13 in forum General Tech Discussion
    Last Post: 09-07-2013, 11:38 AM
  5. Need a Case relearn?
    By des19 in forum PCM Tuning
    Last Post: 01-07-2013, 11:29 AM
