Thread: 2000 suburban brake line
Results 1 to 6 of 6
  1. #1 2000 suburban brake line
    GTP Level Member
    Oct 2014
    The brake line from the ABS module to the rear axle on my 2000 suburban has developed a leak. It looks to be about 1-2 ft behind the module.
    Got to love salt and rust.
    Has anyone replaced one? Looks like a PIA to change. Any tips or tricks??
    Thanks for any thoughts.
  2. #2 Re: 2000 suburban brake line
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Look to see if you can find a fully-assembled replacement with correct bends and fittings pre-installed.
    I chased this dragon on my GTP that was rotting underneath from too much winter driving, and actually bought lines w/ correct fittings from NAPA (matched bends myself), and they worked great for the last 2-3yrs I drove it.
  3. #3 Re: 2000 suburban brake line
    GTP Level Member
    Oct 2014
    Picked up a set of pre bent stainless steel lines. Will start the project today.
  4. #4 Re: 2000 suburban brake line
    GTP Level Member
    Oct 2014
    Completed the brake line surgery in about 4 hours today.
    You can tell they put these together with the body off the frame. 15 min job then.
  5. #5 Re: 2000 suburban brake line
    St. Louis
    Not a bad time for that. I've replaced all of the hard lines on my boss' 98 F150 so I know exactly how hard/time consuming that can be. I really wanted to remove the bed so I could get the rear line done but I fought through it and got it routed correctly in the end, was just such a PITA. I hate rust!
    BTW, that 2K 'Burb looks really clean for that year. If it's got body rust it hides it well.
  6. #6 Re: 2000 suburban brake line
    GTP Level Member
    Oct 2014
    It is pretty rusty. Rockers gone and I use a HD sheet of vinyl painted to match over the big holes in the front of the rear tires. You can see some orange. Needs a touch up after the car wash.
  1. 2000 suburban power steering quit
    By markpa in forum Off Topic Discussion
    Last Post: 06-19-2017, 10:25 PM
  2. 2000 suburban 5.3 l bad intake gasket?
    By markpa in forum Other Vehicles
    Last Post: 01-19-2017, 09:33 PM
  3. RF brake line
    By jpe in forum Brakes/Suspension/Chassis
    Last Post: 01-18-2012, 12:39 AM
  4. Brake line under car
    By donalda in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2011, 12:49 PM
  5. ZZP's 5th Stainless Brake Line!!
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 06:06 PM
