Thread: 03 Grand AM wheel bearing-like noise
Results 1 to 5 of 5
  1. #1 03 Grand AM wheel bearing-like noise
    Donating Users GT2000's Avatar
    Oct 2017
    Central PA
    I replaced the drivers front wheel bearing and noise is still present. I noticed when i spin the tire in neutral i get a high pitch screech from in toward the transmission, on both sides. If i stick my head in the wheel well it sounds like its from in there somewhere, not the wheel bearing. If i jack both tires up and put in any gear and run it, i get the growl the faster i go the worse it gets, and in neutral i get the noise too when the wheel is spinning. In park with both off the ground and i spin it i dont get the noise. I have a ABS, trac off, Service Vehicle (not engine) Light, and i had E brake light that came on when you started driving but it stopped doing that, i think that was unrelated. The car has 213k miles and runs and shifts really good! I got a drop of fluid off the cap of the trans (sealed trans-no dipstick) as a sample and it didn't look to bad, so i think it was changed before. Let me know if anyone has any idea, because im clueless.
  2. #2 Re: 03 Grand AM wheel bearing-like noise
    if you got a odd2 bluetooth scanner like for a t app, this asb scanner app works with it. i have it it works. ChevroSys Scan Free (OBD2 & ELM327 for Chevrolet) - Apps on Google Play
    check the dust shields on the front brakes, they tend to get moved a bit and rub the rotor. only hear it when the wheels spin fast some times. i thought i had a bad hub and it ended up being the shield rubbing.
  3. #3 Re: 03 Grand AM wheel bearing-like noise
    Oct 2017
    Central PA
    I had the wheel rotor and caliper off and still had the squeak noise.
  4. #4 Re: 03 Grand AM wheel bearing-like noise
    im out of ideas then. that app will read your abs code tho. might be related.
  5. #5 Re: 03 Grand AM wheel bearing-like noise
    Oct 2017
    Central PA
    Lol, yup. I dont think the axle would do that would it?
  1. 2008 Grand Prix Wheel Bearing/Hub DIY?
    By veener79 in forum General Tech Discussion
    Last Post: 01-27-2013, 07:34 PM
  2. 2008 Grand Prix Wheel Bearing/Hub DIY?
    By veener79 in forum How To Write-Ups/Tech Tips
    Last Post: 01-26-2013, 04:53 PM
  3. Low speed Wheel Bearing Noise? -97 GTP
    By 3R1CD4V15 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2012, 04:11 PM
  4. Remove Front Wheel Bearing Hub Grand Prix Impala Regal
    By 1ATony in forum How To Write-Ups/Tech Tips
    Last Post: 10-18-2011, 10:35 PM
  5. brand new wheel bearing, same old noise
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2009, 09:09 PM
