Thread: Junkyard rescue of an '87 Dodge Power Ram 50
Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 221 to 240 of 276
  1. #221 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Chats
    10330
    10w-30 is what most run, I'll probably run 10w-40 for a little bit extra viscosity.
    I was thinking VR-1, but if diesel oil has the zinc I'll run the Rotella or Penzoil varieties.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #222 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    I promised a pic of the cylinders, so there it is.
    2020-01-31_03-14-30 by Ben Stryker, on Flickr
    This rebuild might not last another 200k, but the next rebuild will.
  3. Likes ItHurtz liked this post
  4. #223 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Found a small issue with the cylinder head...
    2020-02-20_06-25-05 by Ben Stryker, on Flickr
    There's a coolant passage that runs right in between the valve seats, so all the time and effort I put into the head was wasted.
    But I found a damn good deal, and I'm pretty stoked about it.
    IMG_20200227_135709057 by Ben Stryker, on Flickr
    It's an improved casting... It's much thicker in between the valve seats for better heat dissipation, plus the intake and exhaust ports are improved over the stock casting.
    IMG_20200227_135821715 by Ben Stryker, on Flickr
    And I got a couple extra bits with the head:
    All new intake/exhaust studs
    A set of dowel pins for in between the head and the block
    A set of dowel pins for in between the timing cover and the block
    And finally, a new oil pump gasket that ended up being free.
    I needed new studs, because I destroyed some of the old ones pulling them out of the old head.
    I needed the new dowel pins because half of them were already missing when I pulled the engine apart.
    I needed the new gasket, because I had to pull the oil pump back off and the old gasket didn't survive.
    I've been busy dealing with a metric f*ck-ton of **** lately, and haven't had time to do anything to the truck... But I'm going to try and make some progress this weekend. Hopefully.
  5. #224 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Chats
    243824
    damn this thing best last 100,000 miles........way to many new shiny parts going on it.
  6. Likes tomsteve liked this post
  7. #225 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    IMG_20200227_135222945 by Ben Stryker, on Flickr
    Apparently this picture didn't make it into the post...
    As for lasting another 100k... I'm happy if it lasts 10k, because I'm planning on tearing it back apart later and fully building it, either for boost, or for the giggle gas.
  8. Likes Scottydoggs liked this post
  9. #226 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Finally had a chance to start working on the truck today, and before I even pick up a wrench my buddy stops by and asks for some help with the truck here just bought...
    He picked up a '95 GMC Yukon for $100, it's got some electrical issues keeping it from starting but it's in really good shape for $100. It's got a 350, auto, 4WD, and it's a light blue metallic. There's a little bit of rust in the body, but the frame is pretty damn minty.
    I'm only a little bit jealous... I swear. Lol
  10. #227 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Got the new head assembled
    2020-03-08_08-14-24 by Ben Stryker, on Flickr
    I'm going to keep working on it tonight and tomorrow, and hopefully by the end of tomorrow it'll be ready to go back into the truck.
  11. #228 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Didn't quite get the engine back together, but I did make progress. The rear main seal is installed, the new dowel pins for the head and timing cover are installed, oil pump is re-packed with actual Vaseline and ready to be installed, and I cleaned out the bed of the truck in preparation...
    I'm getting ready to hook up the pressure washer and attack the front half of the truck while the engine is still out, get rid of as much of that built up grime as I can before dropping the engine back in. I'm also going to spray off all of the accessory brackets and pulleys, and whatever else might still be dirty.
    I also started working on the gauges, after finally deciding where I'm going to put them. Now I'm working on figuring out how I'm going to route the lines for the oil pressure and the coolant temp, getting the wiring situated, flipping the gauges in the bracket so I can mount it to the dash...
    Oh, and I ordered a jug of Lucas High Zinc SAE 30 engine break-in oil, and a bottle of LiquiMoly CeraTec friction modifier. I still need to buy the coolant, oil filters, and some more black spray paint, but the end is in sight.
  12. #229 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Mar 2014
    Tucson
    Chats
    2468
    Quote Originally Posted by WarStryker13 View Post
    ...and I cleaned out the bed of the truck in preparation...
    The best part of building a truck; Built in storage space.
    SuperClean from WalMart seems to work the best. I put it in a little pump type garden sprayer. Saves the hand fatigue from a spray bottle. Don't waste your time with that weak sauce Purple Power.
  13. #230 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Built in storage, that I tend to pile anything and everything into while I'm working on the truck... But now it's just the hood and grille sitting in the bed.
    I tried Purple Power at first, but yes, SuperClean100%, and I even have a little pump sprayer from Aldi's that I got for $5.
    I'm not going to use too much degreaser on the engine bay and front axle/suspension, because I want to leave a thin layer of oil/grease so it doesn't start rusting immediately...
  14. #231 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Antioch, IL
    Chats
    156024
    Iv never had a problem with industrial degreaser from menards. **** will take paint off a over the range vent.
    2009 Challenger SRT8
    Expert at being gay.
  15. #232 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    I got most of the big chunks knocked off of the engine bay and front drive train, and most of the grime off the front accessories and brackets. There's still a little bit here and there, but that'll be easy to clean up.
    I'm pulling the #4 rod cap off again, I decided that it's a little tighter than I'd like and I'm going to polish the rod journal a bit more. It would probably be fine the way it is, but better safe than sorry.
    I also picked up a couple oil filters, the only things left to buy is fresh coolant, fresh gas, and another jug of oil. Oh, and rent the engine hoist.
  16. #233 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Number 2 connecting rod was tight as well, so I'm just going to polish all four rod journals.
  17. #234 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Two and four were still tight after polishing the journals, so I swapped the bearings to number one connecting rod and those two bearings do not rotate freely on any journal.
    I'm claiming wrong size bearings, and I've already ordered a new set of rod bearings... It's apparent that plastigauge wasn't the most accurate way to measure, but if the new bearings rotate freely around the journals after torquing the rod caps I'm just going to run them. I'm tired of finding problems.
    I'm still working through this new plague, because essential, but part of me hopes that I get exposed so I can have some time off and actually finish this pile of crap. Without dying, of course.
  18. #235 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Chats
    3223
    COFF, COFF, Dammit, gimme some time OFF !
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  19. #236 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Apparently a 99.8* fever is only good enough for a three day weekend, that I already had off.
  20. #237 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Kemmerer, Wyoming
    Chats
    60223
    they say it needs to be 100.4
  21. #238 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Anyways, the new rod bearings showed up.
    IMG_20200401_143605181 by Ben Stryker, on Flickr
    Box looks like it's been on a shelf since the 80's, I'm going to try and get them in today and make sure they fit.
    If everything goes well I might be able to get some progress made.
  22. #239 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Oct 2014
    Frederick, MD
    Chats
    10330
    Progress has been made.
    IMG_20200409_003323729 by Ben Stryker, on Flickr
    All that's left is clean up and repaint the oil pan, then it'll be ready to go back in the truck.
  23. Likes bandook liked this post
  24. #240 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Chats
    243824
    that timing cover would look good if it was polished up. cant wait to see this thing drive.
  1. anything from junkyard
    By t wizzle17 in forum Wanted To Buy - Parts
    Last Post: 07-28-2013, 08:32 PM
  2. Junkyard
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 06-18-2009, 01:27 PM
  3. Presidents to the rescue!
    By Big Dave in forum The Rant Forum
    Last Post: 10-24-2008, 04:29 AM
  4. Oldsmobile to the rescue!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 04-01-2008, 07:09 PM
