Thread: Junkyard rescue of an '87 Dodge Power Ram 50
Page 10 of 10 FirstFirst ... 8910
Results 181 to 182 of 182
  1. #181 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    Jan 2014
    AR
    Chats
    I am familiar with this scenario. Sucks. Dad put rod and main bearings in a 302 in the carport, with engine still in. On a 2300 that seized due to lack of oil, replacing one cam bearing put it back on the road. Just because it quit running don't mean its completely toast. Maybe if you pulled the oil pan for some exploratory investigation, you'd get a better idea which direction to focus on.
    http://chevroldsmobuiac.blogspot.com/
  2. Advertisement
  3. #182 Re: Junkyard rescue of an '87 Dodge Power Ram 50
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Chats
    10226
    Quote Originally Posted by idrivejunk View Post
    It could very easily just need bearings and rings, but I'm still going through the entire engine and checking everything. I'm also going to do a few mods while it's blown apart... stuff like deleting the balance shaft, adding piston squirters, a high volume oil pump, adding an oil supply and oil drain for the turbo, and a few other things to keep the oil where it needs to be and eliminate potential failure points. I'm also planning on taking the block to a machine shop and having it (at least) hot-tanked, possibly machined if necessary.
    Quote Originally Posted by ItHurtz View Post
    even god is saying NEXT
    Yes, next is turbo.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  4. Likes ItHurtz liked this post
  5. Advertisement
  1. anything from junkyard
    By t wizzle17 in forum Wanted To Buy - Parts
    Last Post: 07-28-2013, 08:32 PM
  2. Junkyard
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 06-18-2009, 01:27 PM
  3. Presidents to the rescue!
    By Big Dave in forum The Rant Forum
    Last Post: 10-24-2008, 04:29 AM
  4. Oldsmobile to the rescue!
    By UR LOSN in forum Off Topic Discussion
    Last Post: 04-01-2008, 07:09 PM
