Thread: General GTO info
Results 1 to 4 of 4
  1. #1 General GTO info
    Donating User
    Jul 2014
    Minnesota
    Chats
    Hello all, coming this spring I will hopefully be purchasing a GTO. I have wanted one ever since they released the new body and I can finally get one. What I am looking for is some good need to know info about these cars and things to look for when looking at potential buys.
    I am also interested in the pros and cons of both the 5.7 and 6.0 platforms. Any info will be appreciated, thanks much.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: General GTO info
    Chats
    83662
    Either engine is good, the 6.0 has far more power/torque from the get go.
    T56's are great but are very prone to internal failures with grinding gears and needing rebuilds. If it was abused you can only hope it was already rebuilt or it's tuff as nails.
    The 4L60/65/70e are always a weak transmission, they work good but they will die with abuse.
    The 5.7 has an easier computer to tune compared to the 6.0 that uses a much newer style computer but overall it's not that complicated.
    Inspect the chassis for loose parts, tie rods and ball joints for sure.
  3. #3 Re: General GTO info
    Donating User
    Jul 2014
    Minnesota
    Chats
    Hey thanks
  4. #4 Re: General GTO info
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    I drove a 6.0 once. Never again. Miserably underpowered (my LLT CTS has more grunt), and kept making a beeping noise with no associated dash lights and no clue from the dealer as to the cause. I've seen one as recently as today, and the sight warmed my heart, until I remembered that test drive.
    Good luck if you get one. You'll need it.
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2022, 02:44 PM
  2. General Info: Swap your steel oil pan for an aluminum one
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 04-05-2022, 01:42 PM
  3. first days!!! any info of good info
    By 97gtp83boy in forum Introductions/Noob Questions
    Last Post: 02-24-2013, 02:17 AM
  4. Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    By LowlyfeGTP in forum Visual/Body Modifications
    Last Post: 06-26-2012, 03:14 AM
  5. general tech info needed
    By onetyme77 in forum General Tech Discussion
    Last Post: 05-31-2011, 12:09 AM
